Omega Thermistor to help fight heatsoak/IAT readings
i have seen a few threads on different forums, mainly GTO ones about this. Read a little on teh caddy forums and it seems like a great mod, especially for the maggied cars. Who here has done this? Any consensus on how much of the cage to remove?
I started this mod, but after cutting the cage out and soldering in the new thermistor I was uncomfortable installing it in the maggie because it looked like it could fall right out and run through the engine.
http://kb.ls1gto.com/KB/article.aspx?id=10279 write-up
http://www.cadillacforums.com/forums...up-your-6.html some photos showing the inside of the s/c with the sensor installed
510, so it wasn't snug after reinstalling the thermistor? i read it is much smaller, so do you think leaving the full cage would keep it from possible coming out?
i plan on doing this as soon as i get the parts, it seems very beneficial yet i don't see many posts on it
Yeah I was a little part of that thread. It wasn't that the housing wasn't snug...it is the thickness of the wires coming from the thermistor that made me uncomfortable. They are damn near the thickness of a human hair and after soldering and working with them, it felt like they could bend and break with the turbulence of the air in the maggie lower manifold. I wasn't quite comfortable enough sticking that thing down into my maggie.
What is the difference in the sensor. I know a thermistor is a backwards resistor (resistance goes down as temperature goes up). Does it read the intake air as cooler than it actually is, or is it just faster reading than the OE sensor? Is the OE sensor a thermistor or a resistor?
Maggies have a spot in them post rotors where the IAT sensor goes to get the most accurate reading of intake air temps.
The omega sensors read faster than the stock one so it is more accurate to show temperature changes.
well i'm not saying meth isn't a good option, but this mod would allow you to get faster more accurate readings, so no one has tried this? the GTO uses the adapter harness but we only need to do the sensor modification as we would not need to relocate the IAT
It won't fight heat soak, just provide another temp monitoring point. Maybe useful in tuning the car to the edge a bit more.
The factory LSJ motors in the cobalt has a MAP/Temp sensor. It's kinda fun to watch, sit in traffic temp goes up, get on the gas lightly temp goes down. Do a couple hard pulls to 100+ mph temp goes up.
I did it and cut the cage. I guess it's about a year now with no problems. Temps change as soon as you give it gas. The stocker would barely budge.
Now this is just a thought. But my temps are a bit cooler now. Either the stock senor itself suffered from heat soak, or more likely, the hot air got stuck in the sensor, showing higher temps. The stock sensor has the thermistor in the housing, under the cage. Since the open part (cage) is facing down, I believe it could form a pocket of hot air giving off a false reading. I cut the cage, and made the new thermistor longer so it's in the airflow.
I rarely see my IAT get to the 140s. This is only if I'm in traffic. Then as soon I start moving, and the car is sucking in more air, the temp drops 15* in less than 5 seconds. It'll keep dropping if I can sustain highway speeds. This is all in the summer time.
Cheap, easy mod. I highly recommend it. Although at first, I was also worried about the damn thing falling off.
Tony
PS as for meth, I'm a big fan. But it won't do much with a Maggie if your just cruising around.
Tony
Where are you guys getting this Omega Thermistor part# 44005???
So far I've tried autozone, O'reillys, and the stealership. Trying to get this done tonight or tomorrow before I head out to SNL for the cam and tune. HELP PLEASE. Thanks.
http://www.omega.com/pptst/44000_THERMIS_ELEMENTS.html
Just do it when you get your car back. It won't change any of the tune but rather make it more responsive. I.E. you do a hard run and the IAT's get into the 140's and thus pull timing and power. With the stock thermosister you will hold that temp longer than you will with the Omega thermosister.
Don't think you can source it locally.
I don't know much of anything about tuning, but I guess I was figuring that if the stock unit took longer to get the temps to drop...then the tuner would pull more timing and tune more conservatively than if the sensors indicated cooler temps right??
accurate, air, cadillac, cts, ctsv, iat, maggie, maggied, omega, relocation, sensor, temp, thermisistor, thermistor, thermosistor, tuning
