What parts wear out in the front end??
As you guys know from my other threads, I've been in a maintenance kick and I'm now wondering what parts in the front end I should need to replace under usual maintenance at 112k miles. I'm referring to bushings, tie rod ends, endlinks, ball joints... Whatever? I just want to make sure everything under there is fresh and tight.
Any particular things I should need to replace at this mileage?
Thanks again in advance!
Lol! Good point! Nothing is broken thank god! I'd just imagine though that 112k miles would put some wear and tear on the bushings and stuff up there and thought it might not be a bad idea to replace/upgrade that stuff.
I'm at 95k on my V and I throw that car around a lot! Everything is still tight. I did pads and rotors the other day and thought the front right wheel bearing made a little noise. It didn't have any slop in it but just didnt sound right so I replaced both front hubs with new ones I had bought a while back. Well, the new passengers side I put on makes more noise than the one that has 95k miles! I'm gonna take it off and put the old one back on.
Prime example of,"if it ain't broke, don't fix it!!!"
My mounts must have been changed because they appear to be in good shape. I guess I'll just dive under there and take a close look at everything else. Maybe I'm just **** but it seems like on abrupt bumps, I can feel a tiny bit of play up there. But then again, maybe it's my imagination... Lol
Good suggestion. I'll take a look at mine and see how they look. I've always been told poly is best for durability but I don't want any squeaks. That would suck!
