New KATECH LS9X clutch kit for CTS-V
this is very true. my twin works for me with how i used my vehicle.
ive decided this summer im either getting a maggie, or doing H/C/I (with a Nitrous Outlet plate kit for when I drag race).
Just a word of advice, build a car for one thing lol . **** gets insanely expesnive if you try and build a car for multiple purposes. Road course and drag strip couldnt be any more different. But if I were you and wanted to focus on road courses id go with a solid heads/cam setup because heat soak would kill you with a maggie.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
We have expanded our LS9X clutch line to another model, 2004-2007 CTS-V.
![](http://www.nexternal.com/katech/images/KAT-A5198_lowres.jpg)
-For 2004-2007 Cadillac CTS-V
-Twin disk clutch
-Clutch disks and pressure plate from the ZR1
-Aluminum flywheel with 6 bolt pattern for standard LS engines
-Includes flywheel bolts
-Includes pressure plate bolts
-8lbs lighter than the stock Z06 clutch/flywheel assembly
-Flywheel weighs 12.0lbs.
-Drives like a stock ZR1 - stock pedal feel
-Proven to 700rwhp (drag racing) 800rwhp (street)
-800+ ft-lbs torque capacity
-No neutral noise or chattering
-All of the benefits of a twin disk clutch and none of the trade-offs
http://store.katechengines.com/ls9x-...ts-v-p247.aspx
-Twin disk clutch
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Our Corvette kits come with a slave because the ZR1 slave is a required part of the conversion. Luckily, the CTS-V slave is short enough to allow the swap without replacing the slave. The CTS-V slave is over $400 at the dealer, so we left it out of the kit to reduce cost and let the customer decide if they want to replace the slave or not. The master cylinder does not need to be replaced.
Dang, didn't notice there were two threads: LS9R and LS9X.
I bought the LS9X kit a couple of hours ago from Jason, not the LS9R.
Just want to be clear on that.
#32
yup your stock one will fit, but judging on its current condition u might just want the piece of mind to change it while your in there. but from what i understand the kit works because the size of our stock slave is "short" and allows everything to fit nicely thus to cut down on cost KATECH doesnt put a new one in the kit its an option
#33
