Got my OBX headers today, first impression.....
ALSO A VIDEO!!! YEAH!
http://www.youtube.com/watch?v=ReXkC7aG52I
obx
why is that?I have heads that flow app. 330cfm @625 lift....with a rear mounted turbo.....the exhaust valves will stay open a lot longer due to the duration of my new bullet cam...i am not a mechanic nor builder but it seems to make sense to get all that exhaust flowing quicker to the rear turbo....i will ask my builder and check ....thanks for bringing that up, cause u might have a point there ps: i have heard that the stock exhaust system flows very well, so maybe headers are a waste of $$ anyway
1-7/8 headers vs 1-3/4 with a turbo will result in delayed spool time due to the velocity of the gases exiting the motor. Your piston is going to push the exhaust out, that increase pressure in the exhaust system helps spool your turbo sooner. Doesn't matter for s/c setups because they are belt driven. Getting gases out as fast as you can makes a more efficient motor, but in reference to turbos.... Whole different theory!
i installed them on thursday, and everything went smooth, EXCEPT the steering shaft DOES rub against the header. im gonna jack up the car tomorrow and see if i can hammer it a little. i dont feel like taking the header off the car to do it though. and i also didnt see the need for header wrap. i did purchase some DEI cool-tape though and put it in some places just in case.
More important is to keep the gasses as hot as possible and install the turbo as close to the exhaust ports as possible. The heat energy help spin the turbine, in addition to the velocity (which I believe could increase with heat). Partially why manifolds (cast iron) work so well vs. headers, in that regard.
There's a lot to an effecient turbo setup, obviously, and much of it's been covered elsewhere so not gonna bore ya here
#34
I installed these, picked up 24 rwhp with the stock cat-back. The steering shaft seems to rub a little... going to bang it out whenever I get some free time.
It was a BITCH of an install for mine. Not sure why. Everyone else had easy times but mine was ridiculous... took 9 hours... but it did give me a reason to replace both engine mounts too, so that was nifty.
The headers seem to be great quality... the girlfriend got me the right present this year =P
Now at 372 rwhp... Next is cut-outs and our NSSP cam.
#35
do you have any pics of your exhaust set-up and is it loud with the factory catback? i wanna put some headers on but i dont want my **** all loud. to me, that would defeat the purpose of driving a cadillac. i guess im getting old! lol!
#37
That's GREAT bang for the buck...I'm glad to see some #'s on what HP these picked up. As far as the difficulty factor, it seems to vary by vehicle.... Surely the headers can't be that different by set.....I know there was a lot different clearance issues before changing my motor mounts.
#40
