anyone attempt dropping the oil pan without motor removal?
CTS-V Shifter Sales
The seal is riveted to the pan, it will stay in place. However, I don't think you can get the pan out from over the crossmember because there is only about 1/2" of clearance from the inside of the bottom of the pan to the oil pickup tube. You would have to at least raise the motor. That's easy enough by just unbolting the mount brakets from the block.
Thought about that... but is raising the motor enough? - I should have stated that in the beginning.
I guess no one has attempted this...
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
Ther is a way but it will not be fun i can tell you that MUCH well what i did was that i put the car on 4 stans and i got an engine hoist and put a strap and whent from header to header you have to undo the motor mounts and i put a hidrolik jack under the front drivetrain and take off yhe 6 bolts that hold the front drivetrain and lower it as much as you need to work if this helps but you need more help you can PM me and ill give you my cell so you can call me may god be with you lol
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
Im pretty sure you have to seperate the motor from the cradle... so you would have to have a cherry picker to hold the motor from the top while you removed the cradle. Of course while the car is up on 4 jack stands.
With the cradle out of the way it would be pretty easy. Id make sure to put a couple jack stands under the motor/trans too just to take some stress off the cherry picker. Just make sure the motor doesnt move too much as you can break stuff off the back of the intake if it hits the body.
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x901/16817590257507081481472628071365_e8aeafbf289e0ec1c976f59e53fd82e9b1d3b889.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x901/16817590714095642213242292608440_a1934bdb30db41aa55087e8411c1e5781471b61d.jpg)
