max width tire on the V
I am a chrome man myself, BUT, i have the platinium silver and the stock silver wheels that look great with this V..and it is still a stock rim....If i had a raven black or burgandy,or any other color i probably would go aftermarket.
IMO, SILVER V and SILVER RIMS make a good lookin combo....Where i went wrong was listening to MAPS advice.
on the size of rim and tire i used.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The stock rims widened to 9-3/4'' has to be the best fitment..just enough room to miss the stablizer bar and with 285's the tires on the outside barely fit inside the wheelwell and that's with the Map trl. arms..One can't do any better than that. When u buy a 10" rim i measure inside to inside not outside to outside...I have spent too much time and $$$ in trying to get 315's under the V..Including all the tires and mounting i have spent 3K...I am happy with stock rims.. i want to look basically stock..NO ugly specter works side skirts or aftrmarket wheels..295's, Eibach springs, and maybe a functional good looking hood, and a pretty quiet exhaust with 650-750rwhp is all i want.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
After my all forged 405" is done in 3 weeks i will have it installed with the rear turbo that is in there now...But that setup has to go cause, there is no muffler system and i don't like the popping sound i get when i shift or let off the gas..
So, i will be buying a 92mm /t4/.96 ar probably from Jose'.. This will be needed to make up for the xrtra cubes i have plus i will be able to run less boost and retain good power, and help protect the engine....and like i said b/4...the 18" rim looks great since the V is well lowered and i don't need a taller rim to make any more problems...If i had to do the rim thing all over again, i would use C5hubs with the 5 lug and if the stock grey speedlines didnt match i would have something like the C6Z06 rims painted to match the silver platinum..
Anyway for the OP 9-3/4" is the limit on stock rims..or do a search on C5 hubs and go with Corvette rims or Camaro rims et. etc.....seeyall'
big GREG O. btw i did NOT know about the optional split7's
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Wavey](https://ls1tech.com/forums/images/smilies2/wavey.gif)
stock like a day after i got it
![](http://i45.photobucket.com/albums/f82/spencer1715/untitled.jpg)
heres the wheels (still have them)
![](http://i45.photobucket.com/albums/f82/spencer1715/35733_421941383616_784458616_4182870_6619379_n.jpg)
stock ride height 18x9.5 racing wheels cant remember company but Luke at the caddi dealership can order them. I fit a 295 in the rear but they poked 1/4-3/8 of a inch and the BFG Drags lasted a few weeks...
I then went with the BFG NKWs in a 285 and loved them flawless fit no rub and no poke. I would stick with a 285 in the rear. I also ran a 13.01 @113.xxx with the BFG NKWs
pic is with the 295s u can see poke in rear.
![](http://i54.photobucket.com/albums/g99/blloyd6920/sideview295s.jpg)
![](http://i54.photobucket.com/albums/g99/blloyd6920/cobyside-1.jpg)
![](http://i54.photobucket.com/albums/g99/blloyd6920/sideangle-1.jpg)
Check the cts-v parts page.
Den is running 10" with 295's, map trailing arms, lowered 1 1/2", with 8mm spacers.
![](http://i106.photobucket.com/albums/m276/JD03Cobra/001.jpg)
![](http://i106.photobucket.com/albums/m276/JD03Cobra/P8154114.jpg)
#32
On the parts page it list him as having all the things I listed. But on the caddy forum I just reread, his rims are 9.75" w/8mm spacer, he figures he can run without.
He was the one that suggested I'd be o.k. with my set up running a 5mm spacer.
Quote from Den
Quote from Den
I'm running 255/40/18 on Front stock wheels and 295/35/18 on back with widen stock wheels to 9.75 and coilovers about 1.5in lowered. I have the MAP trailing arms, longer studs and an 8mm spacer. My rear wheels do not stick past the fender well at the top. I was being conservative when I did my setup. I think you can go 10in wide rim with a 5mm spacer (non-hub centric) and the MAP trailing arms (not sure if you need longer studs, it will be close). Don't use the anything less than 5mm for a spacer because they will probably crack. The size spacer will depend on which tire you use. The largest spacer you can go is about 14mm before you stick past the fender well with my 9.75mm wheels.
#33
#35
Nice dog.
#36
old thread here, but my wheels are currently @ weldcraft to go from 8.5 to 10, but I'm almost sure they are going to hit the swaybar.
Do any of the aftermarket bars increase the clearance?
Should I change my order to 9.75 before it's too late?
Pilot Super Sport 285/35's are waiting on the rims.
#38
Good to know! I just updated my ticket to go 9.75 instead of 10.
Just wrapped up my CS wide wheel trailing arm install, along with their toe rods, and an LS7 clutch / flywheel / slave swap.
I have the car back on the ground and I can see the stock swaybar is definatley going to hit. even at 9.75
How much room do you have with the MAP bar? (any suggested vendor / sponsor to go through?)
Thanks!
Thanks!
#39
Is MAP out of business? If so put an ad on forum and get a set. I ran Eibach springs, but that shouldn’t make a difference
. With the MAP arms which made a big difference I ran 285’s . U might be able to use a spacer. I did not and there was only a 1/8” of clearance. To test your 9.75 rims use 6 flat waders on studs and check fitness.
ps: I sold my car to my brother in law. and I might have 295’s on them. I would need to call him. I also have a pair of stock rims I don’t need in real good condition..good luck.GREG O.
My computer is down and I use my I-phone. So I have limited access.. What city and state do u live in? I might be able to help u more with my 9.75 rims. Did u get them widened yet?
GREG O.
GREG O.
#40
I purchased a pair of stock wheels on eBay and had them drop shipped to WeldCraft Wheels.
I received a confirmation that the wheels spun straight / true. They are pretty backed up right now and havent made any moddifications yet.
I cut a block of wood at 1.25" and went under my car. It grazes the bar on the pass side, and bumps it pretty good on the drivers side.
I ignored where the tire might rub since I have 265's squeezed on 8.5 now, and there should be some relief with the wider rim. (New 285/35's awaiting the rims)
Since I just put in new toe rods, my alignment is only 'close' I stuck the rotors on the hub as a visual guide to sight in / line them up with the front before putting the stock wheels back on.
I would be really curious to know how much clearence your MAP bar left you with, or if they are out of business. I believe Hotchkis makes a bar for our cars as well.
I'm located in Minnesota.
