max width tire on the V
#43
Bought MAP arms. Guy was arragant💩POS. Do a search on the other forum. First post he said 335’s would fit. So I bought 4 Toyo’s But 305’s to be safe. He said 10” rims. Believe me I could only go with 285’s. with his freakin arms and had to shave off app. 3/6” off rear bar. Just use 275’s on stock rims. or buy my 2011 grand sport all black, just put 285’s up front and 345’s/30/19’s on the rear👍 😉 good luck
#45
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/imag2097_56ba41660a44a10a13f09bd9ab11622fb81657dc.jpg)
295/35R18 on 10.5"
I just mounted my 295/35R18's to my widened 10.5" Accessory wheels. These are not a bolt in thing. A small spacer will be required ~5 to 7 mm most likely and the control arms are going to need to be trimmed and boxed a little otherwise you'll machine the inner barrel of your wheel. Everything else seems to fit ok in there. This won't work with stock springs either. The smaller diameter springs that come in most coilover kits are required.
#46
295/35R18 on 10.5"
awesome!!
#48
old thread here, but my wheels are currently @ weldcraft to go from 8.5 to 10, but I'm almost sure they are going to hit the swaybar.
Do any of the aftermarket bars increase the clearance?
Should I change my order to 9.75 before it's too late?
Pilot Super Sport 285/35's are waiting on the rims.
