I need help now, oil pres. issue
Everytime i get the rpm to about 2,700rpm my oil pressure goes to 0 and comes back after after the rpm drops down. What can it be, open to all ideas, i dont want to lock up my motor.
I ask the obvious questions first. Dose the engine make any odd noises or anything when this happens? If so, I'd say stop driving and replace the oil pump. If not (and this is the most likely cause) I would replace the oil pressure sending unit and see what happens. It's near the rear of the engine behind the intake on the drivers side. Sensor should pretty cheap from a parts store.
there is no knocking but y only at that rpm and above, and where is the oil pressure sending unit located and if u know the cost of replacing both would be helpfull
Talked to dealership, guy was really helpfull, since im not the original owner and dont know the history of the servicing done he said there might be sluge getting stuck on the pickup tube in the screen and blocking it. I think i might drop the pan and inspect myself. What do u all think about that being a reason?
From the other forum:
http://www.cadillacforums.com/forums...r-failure.html
In the first post:
"The part number for the sensor/sender is 12616646. GM sells this for about $75. GMPD price, including shipping, was a bit over $50."
I just did mine, but I got a BWD part from the local O'Reilly Auto Parts store. The price from the local store was only slightly less than GM Parts Direct (within $5).
In the first post:
For procedures and diagrams I've always found alldatadiy.com to be very worthwhile. I used it when I built the motor on the mustang in my signature, and there was very little it didn't cover. What it didn't cover was a result of the motor being supercharged, which didn't happen from Ford.
I think its ~$15 for the year, and Pete I am pretty sure it would give you a step by step on replacing the oil pressure sending unit.
