LS7 clutch upgrade question
I would have to change the flywheel as well for an LS6 application right? Is there any reason why this flywheel might not work? http://cgi.ebay.com/ebaymotors/ws/eB...fvi%3D1&_rdc=1
Thanks for any responses.
That's the one that I'm using for my LS7 conversion. Try this guy for the OEM clutch:
http://cgi.ebay.com/ebaymotors/GM-Pe...item4157b228b1
And don't forget to get 6 new flywheel bolts (GM part number 11569956). I didn't realize that I needed them until today. A pack of 10 of them should run you about $25 shipped on GMpartsdirect.
I am probably going to do this flywheel with the OEM Z06 clutch as well then.
Also a slave from OReilly's, new flywheel bolts and a remote bleeder.
I don't see why that flywheel wouldn't work. I ran an F1 clutch in my blown mustang for over a year with no issues. Most all of these parts are made by the same manufacturers and re-branded by companies from what I have heard.
