Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Clear fogs guys a quick question.
Old 05-31-2011 | 11:07 PM
MIAdragon's Avatar
Default Clear fogs guys a quick question.
How "watertight" do the lenses need to be? I used bolts to hold the lens in place should I silicone around the bolt hole? I just don't want to see a ton of condensation in the housing. Thanks!!
Old 05-31-2011 | 11:47 PM
Persian-V's Avatar
I've used black rtv silicone and they've held up just fine for my fogs for two years now and they are working great on the headlights I would def suggest using some of that to be 100% on the safe side.
Old 06-01-2011 | 01:20 PM
ferny's Avatar
i did the bolt trick on mine. but most deff. you should put silicone around them cuz the water will get in if you dont. i used some clear silicone from home depot. never had a problem with mine
Old 06-01-2011 | 01:36 PM
DirtyDirk's Avatar
You need to seal them. If not water will get in & start to peel the chrome off. I used Fusor body adhesive on mine. Holds tight & leak free.
Old 06-01-2011 | 03:06 PM
MIAdragon's Avatar
Thanks guys!!
