Passenger side trailing arm & fenders rubbing with new wheels & tires
Well on my drive home from work this morning (gotta love the night shift) I got a little more confident and gave it a bit of a more agreeive run on a few curvy on/off ramps. I wanted to listen for any rubbing and also be able to look in the wheel wells for evidence of problem areas. Unfortunately, that idea backfired on me and I might have f***ed a brand new tire. Passenger side rear fender at about 4 O'Clock took a nice effin trench out of my brand new tire. It's not on the sidewall, but not really through the main tread either, so I'm not sure if the structural integrity of the tire is now ruined, or if the tire is still safe to run. I've emailed pictures to my contact at the US supplier for his opinion, since he's extremely familliar with the construction of the tire. We'll see what he thinks. If it needs to be replaced, hopefully he'll be able to hook me up with a really good deal on the replacement. Ugh... This sucks. All I wanted to do was bolt some nice new "shoes" onto my car and enjoy it for the summer .... nooooo ... it's gotta fight even that simple mod.
Also, I called a few body shops this morning. Nobody that I got a hold of (keep in mind it was a Saturday morning) was very receptive to rolling fenders. All 4 shops I talked to said that the paint WILL chip and that they probably wouldn't be interested in doing the work. Yet another road block... Ugh...
A few pics of the damaged tire:
![](http://i779.photobucket.com/albums/yy71/wes8398/882b3b6c-1.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/4dab393a.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/2eae60cb.jpg)
because before I got my fenders rolled that happened to me. I brought my car in, wiped off the inner fender so they couldnt feel rubber that had burnt off on the inside of the fender. Told them I ran something over and they replaced them. Only thing I had to pay for was 35$ and some change for new tire pressure sensor crap
Unfortunately I don't think I'm going to be that lucky. That trench goes all the way around the tire in a perfect line. Pretty clear that it was self inflicted. Also, I bought the tires direct from a contact I made at the manufacturer's American distributor. He made an exception and sold directly to me. I sent him an email with a few pics and explanation of what happened. Hopefully he'll give his expert opinion and if that's to replace the fire, maybe he'll be able to cut me a special deal of some sort. Here's hoping anyway...
The paint won't chip if the shop heats up the area with a heat gun or blow dryer. The two different shops who did my fender rolling didn't chip the paint at all.
If you can't find a shop to do the work, look up the baseball bat method and do it yourself.
Thanks for the info tweeter. I've come across that baseball bat method as well as modified version of that using ABS pipe instead of the bat.
I'm scared shitless to do this myself, but I might have to because I haven't found a local shop that'll do it yet.
Well I gave the ABS pipe method a try tonight. Jacked up the corner, heated the paint with the wife's hair dryer for a good 10 minutes, then slowly lowered it onto the ABS; attempting to wedge it between the tire and the fender. Unfortunately the area I'm trying to roll is at about the 3 O'clock position and doesn't really lend itself to wedging the ABS between it and the tire. So, that was a fail... No damage though (glass half full thinking).
ALSO .. guys ... can anyone confirm for me where I cut the stock springs from? I don't cut the tight top coil off, do I?? It makes a lot more sense to me to cut from the bottom of the spring, but in doing that you're also eliminating that bottom "flat" coil that makes the spring sit nicely in the bottom perch. Is it ok to cut that flat coil off?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i779.photobucket.com/albums/yy71/wes8398/IMG_1098-1.jpg)
Sorry you're not down here by me, otherwise I'd let you use my Roller. They are available for rent from Tire Rack, or you can buy one from Eastwood like I did and rent it out to locals.
I did the same thing to a tire before I rolled my fenders, went with some Wider Hankooks on my Miata, and when I took a turn sharp while racing, I saw a flurry of black shavings flying up from the fender, which was the result of my tire being cheese-grated against the fender. It sucked, but the tire lasted over a year of daily driving and once a month autocrosses.
-meaty
-meaty
#32
Eastern Regional Coordinator
I had a simialr problem on both of my last cars. Not that i like that hella flush bullshit but I do like a nice wide tire and rim. Well i drove for over a year on tires that were well sliced by a fender... and it held up fine.
Guess I need to find a roller in MD again.
#33
Well I can't seem to find any local body shops that are willing to roll my fenders. I get the same answers from all of them ... first it's a long pause, then it's "well, what do you mean by roll your fenders", then I take a deep breath and explain, then they answer "well the paint is going to crack...", then I hang up. Ugh!
I got a call from the tire manufacturer's rep today. He had a look at the pics I sent him of the damage. He said he couldn't "officially" say that the tire was fine, but that off the record he was confident that the 'damage' was strictly cosmetic and doesn't appear that it'll have any effect on safety or performance. He also said he'd take a picture of a cross-section of that tire that they have, to shop me exactly how far my 'damage' is from being a safety/performance concern. Great guy. Thumbs up.
#34
icing on the cake, they were 3 stars
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
wes, i'm positive that's just cosmetic. i've seen and driven on much worse in the past. my current 285/25/20 nitto invos have some minor scuffs on the sidewall from aggressive driving as they tuck so much when doing so. they tuck almost to the rim now, i've been told by other witnesses (friends) that when they see me turning aggressive the V looks like a damn sled and tucks the 2 tires taking all the force like a champ.
#38
No luck finding a fender rolling tool around here, unfortunately. I was able to find one single body guy that said he can do the job after work on tuesday, no problem. He said he doesn't use that tool though, just lots of duct tape, a hammer, and lots of finesse. He didn't seem worried at all about doing it, but I'm a little leery of the hammer method. But how do I argue with a guy that's been doing this for decades? Anyway, that's a possibility now. Once I raise the rear back up a bit, this fender might not even be an issue anymore anyway. Then I'll just have to worry about the trailing arm and an alignment.
#39
Wanna wait until this guy can do it for us? I have been PMing him about it for a while now. If there is enough interest they can just fab up an adapter and we can all take turns renting it and doing it the "right" way.
Either way make sure the paint is as hot as possible before rolling and keep heat on it as you go. My subaru's paint cracked a little but 2 years later had no issues.
#40
