H&R's lowered rear too much ...
#61
Eastern Regional Coordinator
Other way around. I havent installed my spacers yet but depending on the angle it actually sit very high in the rear as the suspension tried to level out. Once I have the spacers in I would think it would sit at the lower position regularly and try and hold that with the autoleveling.
I could be dead wrong.
#62
Has anyone tried cutting down the MM spacers?
In theory, if the shock is mounted 1" into the trunk, and if you cut out 1/2" of those spacers, then it should bring the shock down 1/2" closer to its original position. Thus, giving you 1/2" back in height.
It doesnt seem like the cars without MM spacers sit too low...
Cars with H&R springs WITHOUT MM spacers suffer from the shocks auto-leveling to what they interpret as sag due to an over loaded trunk/back seat. They raise the back end of the car up after it has been driven around for the appropriate distance. After the car is parked, the shocks eventually settle back to where they were before hand. Depending on when (relative to driving) the car is observed, a car with H&R springs ONLY may be perceived as not being as low in the rear. Additionally, getting rid of the MM spacers will guarantee that you have super shitty ride quality from the rear shocks always trying to pump themselves up while you drive around.
#63
can you post a pic or even better yet the measurements from the ground to the fender well? That would help determine what change the MM spacers has when the car it sitting still.
#64
Do cars without the spacers actually get lower?
Not really...because the rear has load levelers they will try to go back to a the "programmed" height of the shocks. You will still get a slightly lower look, but it will be nothing like with the spacers.
I bought my car with H&R springs already installed, but no spacers. The rear is higher than the front, which I don't mind. Would I be better off putting some stock springs back in the rear to regain my ride quality?
the ride quality will be better with the spacers and your H&Rs. But it not as good as the stock springs. so, either way with spacers or stock springs, your ride comfort will improve.
#69
Was just cruising the new posts and noticed that the f-body guys were doing what they call the "heater hose" mod to the rear springs, which i believe is slipping some heater hose over the end of a spring to give another 1/8th inch of clearance. That paired with some coil spring isolators may give you some more room.
#70
It has leveled out a little bit since the install, they are almost even all around now BUT it was still more of a drop than advertised, that is my only real issue. It's just too close for comfort but so far no rubbing.
EDIT: it was the rear driver wheel where it was the lowest, and still is compared to the other 3 corners. I will check my measurements again to tonight.
#71
the bottom section which is all the same diameter is the end you want to cut just soften the edge good with a grinder before reinstalling.
camn v6 car looks great, nice color!
#73
Wes, here are the measurements after a few days of riding around town. The measurements were all taken first thing in the AM with cold tires.
Driver Front - Before - 27 1/4" - After - 25 7/8"
Pass Front - Before - 27 1/2" - After - 25 7/8"
Driver Rear - Before - 27 7/8" - After - 25 6/8" (2 1/8" drop here)
Pass Rear - Before - 27 5/8" - After - 26 1/8" (only 1.5" drop here)
Overall the car sits pretty even, the only place that bothers me is the Driver Rear, that 3/8" difference is the problem I have. Might see if I can adjust the MM spacer any to fix that.
#75
so, if I swapped the two rear springs in theory I should see those numbers flip flop? I have no problems with your spacers, I just want the car to sit the same on both sides. I don't have any rubbing issues, all I want is for both sides to be equal or at least closer than 1/2".
#76
I cut my stock springs this afternoon and swapped 'em in place of the h&r's. For those of you saying that the MM spacers were what was making me "too low", can you explain how these 'new' springs now have my rear fenders a 1/2 inch higher with spacers still installed? After cut spring install and a drive around to seat them, my rear fenders are now between 26 3/8" and 26 1/2" off the floor with the cut springs and MM spacers. Half an hour prior, with the H&R's and MM's, my rear fenders were 25 7/8" off the floor.
With cut OEM springs and MM's installed:
![](http://i779.photobucket.com/albums/yy71/wes8398/IMG_1119.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/IMG_1116.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/IMG_1121.jpg)
What I took off the OEM springs:
![](http://i779.photobucket.com/albums/yy71/wes8398/IMG_1120.jpg)
Fender measurements were all taken with the OEM wheels and 245/45-18 Toyo Observe Garit winter tires on them. For the last week and a half or so I've been driving around with my summer 'shoes' on the front, and my winter (oem) 'shoes' on the back because of the fitment issues with the LC's (Linea Corse's). As much as I hated to do it, I didn't want to wear down the winter tires any more than I had to. This 80+ degree weather is far from ideal for a winter tire in terms of longevity. lol
So, I didn't take the pics til after I put the LC's back on the back, so I could compare pictures from when I had the H&R's on with them to now.
#78
Unnecessary attitude, dude. And it's 3 topics, not 4.
As you can see by the titles, they were all intended to be separate topics (although related, still separate), but they all seemed to meld into one big thread. I copied & pasted a few posts to each thread because those that find themselves searching whichever topic would probably find the info useful.
If a moderator would like to somehow scrunch these 3 threads all into one, that's fine by me.
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
#79
Not an attitude, all of your threads have one common issue and it would make more sense to just have one thread or reply to one thread about it. And its 4 threads you started
1.) H&R's lowered rear too much ...
2.) Passenger side trailing arm & fenders rubbing with new wheels & tires
3.) Did your recently purchased H&R springs drop you more than advertised? Please read.
4.) What's the verdict on MAP trailing arms?
