Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What clutch should I get?
Old 11-29-2011 | 11:38 PM
Squid4life's Avatar
Where are you guys getting the LS7/9 clutch kits? Dealership?
Old 11-30-2011 | 12:04 PM
heavymetals's Avatar
I ordered from Katech.
Got it sitting on the floor, waiting for install.
Old 11-30-2011 | 12:40 PM
tony tone's Avatar
my ls7 clutch kit is phenomenal. i heart jamie. purchased from his dealer.
Old 11-30-2011 | 01:05 PM
TexVette's Avatar
Originally Posted by Nowhereman
McLeod twin disk street.. it's the perfect street / race clutch.
+1
Would not run a spec again. McLeods can be rebuilt, so when it does start to slip (never ran one to end of life) you don't have to buy another complete clutch. Their turn around time was very good as well. Stiffer pedal though.
As far as stock clutches like ls9 and ls7 I just don't have any experience running stock parts in higher hp applications.
Have run a RAM clutch before with no problems, but I do not buy their products any longer due to master cylinder failure and warranty problems. (bought their adjustable MC and it failed quickly and they wouldn't replace)
Old 12-06-2011 | 09:33 PM
sandman22's Avatar
Originally Posted by TexVette
+1
Can you run a LS7 slave with the twin disk McLeod?
Old 12-06-2011 | 10:19 PM
1BADCTS's Avatar
Originally Posted by UnsafeAtAnySpd
I'm sure most people will end up suggesting the clutch they themselves run. That said, I have the LS9 kit and really like it. Drives pretty much like stock but revs way faster and should handle quite a bit more power.
Not me! I have a Monster stage 3 and I would avoid it like the plague. I can't wait to pull it out of there. It chatters so bad I'm embarrassed to have people ride with me.
Old 12-06-2011 | 11:58 PM
Originally Posted by 1badcts
not me! I have a monster stage 3 and i would avoid it like the plague. I can't wait to pull it out of there. It chatters so bad i'm embarrassed to have people ride with me.
ditto
Old 12-07-2011 | 11:22 AM
TexVette's Avatar
Should be able to. Pedal effort might change a little. Depends on the clutch you go with also.
I've always used stock slaves with clutches, but upgraded the master cylinder to adjustable at the very least but ideally with a slightly larger bore to push more fluid. I'm putting a McLeod twin in my V at the end of the month and am hoping the stock hydraulic system will work for the time being.
The McLeod in my C5 was stiff but longevity and reliability at higher than stock (a lot higher) power levels was my priority. Also, it wasn't *that* stiff. Just lets you know you're not in a honda civic.
I saw that you're having problems with the McLeod Slave which is a bummer because I had considered getting one.
Old 12-07-2011 | 11:56 AM
sandman22's Avatar
Car has either the RST or RXT
Old 12-07-2011 | 01:10 PM
1BADCTS's Avatar
I wish there were an adjustable option for the 'V. I am not aware of one.
Old 12-07-2011 | 01:16 PM
sandman22's Avatar
The 1400 series slave is adjustable. That's what was in my V
Old 12-07-2011 | 01:20 PM
  #32
Gaspo's Avatar
i like my monster stage 2. feels almost stock. grips great. never had an issue with slipping or anything. my car makes over 540 rwhp
Old 12-07-2011 | 01:29 PM
  #33
TexVette's Avatar
I was referring to the adjustable master cylinder.
I'm going to try to retrofit a C5 Mcleod Master Cylinder into the V.
If I didn't know I had a mcLeod in the car, then took it apart and discovered that's what in there, I'd be pretty damn happy.
Old 12-07-2011 | 01:39 PM
  #34
1BADCTS's Avatar
I e-mailed Monster and they said I can change to a stage 2 and re-use my pressure plate and flywheel. I'm relieved! I may try to do this over Christmas. I just need to figure out how to get the damn thing high enough in the air to pull the tranny...
Old 12-07-2011 | 02:02 PM
  #35
I figured you could replace the clutch plate with a disc.
I just decided to replace the whole thing.
Old 12-14-2011 | 03:47 PM
  #36
HurleyStreetracer's Avatar
Thumbs up
I'm runing a Monster Stage 2 in mine and it seems to work great! I'm only making like 430-450 to the wheels though, I'll no my exact numbers friday morning when I get it tuned in Hennesey, Oklahoma by Dewayne.
Old 12-14-2011 | 04:09 PM
  #37
9t8z28's Avatar
Centerforce DFX 12"! Best clutch stock feel. Remember, the stock clutch is 11" and dual disk setups are overpriced for what you get outta them.
Old 12-14-2011 | 06:19 PM
  #38
Would you do me a favor and check your header mounting nuts or bolts for tightness?
Part of my chatter problem was a catch 22 involving the header mounting nuts (ARP 12 points) being rattled loose.
The results were: lost hardware, blown out (in sections) header gaskets, lean codes, and I had to replace the ignition wires which were rattled apart and intermittent (two).
PLUS, it amplified the chatter!
WHAT FUN!
I solved this by replacing the 12 points with high temp locking nuts that are 12 mm giving more surface area contact.
Old 12-14-2011 | 08:58 PM
  #39
1BADCTS's Avatar
I double checked the front two easy to reach ones tonight, but they are good and snug. I ordered my Stage 2 today, hope to have it in before the new year!
Maybe one day I will stop moding this car and start driving it!
Old 12-14-2011 | 11:19 PM
  #40
VeryWhiteDevil's Avatar
I just finished the Katech LS9 twin disc install and so far I really like it.
Planning on going to the drag strip this weekend to test it out.
Quick Reply: What clutch should I get?
