Cam Install Finally
#41
Both those cars sound bad *** and both of them lope hard enough to make me happy. I think that cam in the SS sounds a little bigger to me but not by much. Ill prob go with a torque/mid range cam in this car since it's typically between 2k-4k rpms. Rarely do I wind it out but as long as the power doesn't dump off up top, I'll be satisfied. Like u said, I'm a heavy car like this, that torque and mid-range power will really help get it moving!
I find that my corsa exhaust is really quiet at idle compared to about 4k rpm so that could contribute to you not hearing it much never mind the video quality.
#42
Yeah that's true. The camaro sounded like a straight pipe exhaust. Lol or maybe an SLP loudmouth setup. I'm sure that had a lot to do with the sound difference at idle. If I had my choice, I'd run something quiet but have cutouts as well for when I want to wake the dead... Lol
#43
You are dead on. Your cam is actually bigger and has more overlap than the cam in that camaro I posted. Video quality is one reason and exhaust setups the other. Yours also makes power significantly later too. Your cam has 5 degrees of overlap as opposed to 4 for that 228R on a 110lsa so with the same exhaust setup, yours would lope more.
#46
So in other words it wouldn't be a good choice? What if the springs are rated for a much higher lift than what the cam is actually capable of lifting? Like if the springs were good for .700 lift?
#47
I wouldnt base cam choice on valvespring wear personally unless you put 20k a year on the car. With the MS4 you would want to get them changed out after 20k or so miles. So 250 bucks for new springs and another 90-100 in labor if you dont do it yourself.
I think MS4 in a V1 is way overkill since youll want to wind it out a lot more then a smaller cam. Id stay low-mid 230s.
