Gforce 9" Rear End Install Tutorial Writeup Write Up
#41
I hit up GForce a couple of weeks ago on this issue -
After tightening down the axle bolts there was still play at the hub. I had to put a washer between the hub and the 34mm axle nut. He may have changed the kit up after our discussion, but make sure you don't have play in there.
Happy beating on it now... welcome to the bulletproof V club. ;-)
#42
#45
The new outer stubs are done, let me know when you want to swap yours out to try the new fit.
Thanks
Chris
#48
Yes sir.
http://www.shop.gforce1320.com/produ...&categoryId=13
Give us a call if you need anything or drop us an email.
Thanks
Chris
Thanks
Chris
#55
Thanks
Chris
#59
