Heat soak
Humidity is the bigger killer than the heat, so anything I'd post wouldnt give you much of a guage. It can be pretty substantial though, especially if ur running smaller pulley. This is the reason to go with biggest heat exchanger you can find and meth as well once you bump the boost over stock...ceramic headers, heat extractor hood, CAI that draws air from down low in the bay, T-stat...yada, yada
