Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Broken diff?
Old Oct 27, 2011 | 03:48 PM
blockheadnic's Avatar
Default Broken diff?
I have a 2005 ctsv with a easy care warranty. they declined coverage. the dealer said they will install it for free and give me parts at cost. I asked if i bring in a rearend will they install it for free and they said yes. so my question is other then the oem replacment what other options do i have. Will a zo6 be better, camaro,
If im shelling out 2500 for parts what are my options?
Oh and F**K easy care.
Old Oct 27, 2011 | 03:53 PM
.Houdini.'s Avatar
brand new gen 4 diff should be less than 1600 if they are really giving it to you for cost.
Old Oct 27, 2011 | 04:25 PM
BudRacing's Avatar
I don't believe those other rear ends will bolt in. It would require a custom fabricated bracket to make those work. Why was you claim denied?
Old Oct 27, 2011 | 04:47 PM
raven154's Avatar
Really the only diff that will bolt it is the stock diff or a creative steel 8.8. The Z06 uses a transaxle type so that's a no go. The Camaro uses a completely different diff as well. The older Saturn Sky and the Pontiac Solstice use the same case but use a different gear set and pinion. The new sky and solstice use almost the same case, front pinion mount is redesigned.
Old Oct 27, 2011 | 06:19 PM
atoler27's Avatar
Easycare covered mine and driveshaft.... That sucks man... You should fight it
Old Oct 27, 2011 | 07:04 PM
Yea its the driveshaft and diff. well easy care said it didnt fail because of internal failure. so they wont cover it. i looked the parts up on gm parts depot and with freight it was the same as what they offered. The cost is not a big deal but i just figure if i was already dipping into my account i might as well go big.
The g-force is out of the question. so it looks like a oem one.
What mods do you guys recommend to use. i know the wheel hop j bar thing is a good buy, but what about bushings and the panard bar looking thing from bmr.
I am more mad that i cant drive my car. I live in ohio so i have about one month of driving it before i bust out the lumina lol.
Old Oct 27, 2011 | 07:23 PM
Scott96LT1's Avatar
I'd fight it too. I have Easy Care but hopefully I'll never have to use it either.
Old Oct 27, 2011 | 07:55 PM
BudRacing's Avatar
Show them all the documented cases of Aluminum case failure you can find. Pictures speak a thousand words. Try starting a thread called "Show me your diff carnage" and see how many people post of their thrashed differential pics.
