Rear end/diff/control arm question...
So ive just picked up a 04 V, 57k, intake & exhaust car about a week ago. Driving it home last night 1,2nd gear start up I head a very sh!tty sounding clunking coming from RR wheel/tire area. So the plan for today was to go to Cadillac, for alignment & oil change. I had kinda forgot about the clunk but as im leaving the clunk was still there...so ok, change of plan I decide to take it to a friends shop(specializes in MB & BMW but worked on a number V's & actually just modded out a 09 V...sickkkk)
They put it on the lift, put it in gear & gas it, BOTH rear tires bow out as you initially accelerate then kind of line up/pop back in...on top of this a guy crawls under to remove one of the driveshaft bolts by hand, hoooly crapper!![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Shop says its control arm bushings & diff mount might be roasted too, just a thought but could replacing the bushings be a 'preventative' measure to save from a legendary V diff disaster? Any one else heard or had anything like this happen(other then the loose bolt part, thats just a wtf?)
Get the rear TIC bushings for your trailing arms and the BMR or CS bushing for the diff. Might as well do the CS tranny mount and have them check your motor mounts. I had two sets of stockers fail in 60k miles. I put in the CS motor mounts in after the last set wore out. If you pay for the stock stuff your just going to waste money and or a diff
I've had a squeak in my rear suspension lately. Squeaked whenever i hit a bump. Took the car in for the seat sensor recall and asked them to put the car on the rack to check the squeak. They told me it was the control arm bushing.. They also said gm won't let them replace just the bushing, they have to replace the whole arm. Its $330 for the part and about 4.5 hrs labor. The service mgr was pretty cool and said it would be much cheaper to just get an aftermarket bushing, so that's the route ill be going as well.
I just did the TIC rear trailing arm bushings ($75). It took longer to jack up the car than to install the bushings.
Get the huge C Clamp from sears ($15). Use the spring seat for the top of the clamp. Then screw the clamp in until you press the old bushing out. Put a little non petroleum lube on the new bushings and put them in. Press the metal sleeve into the new bushing with the C clamp. Done. Took about 10mins per side.
