Liquid-intercooled procharger
#41
I don't know about getting the C6 (c5?) kit to fit. From rough measurments it looks like you won't have room for the intake without swapping and moving the radiator. The one posted is not a viable option for a DD. That has no filter and the intake is right behind the grill. You can't drive it in the rain and if you get any debris or thick dust in there (likely with that placement) it could shatter your impeller and break the supercharger and possibly send pieces of metal into your motor. I'm still excited to see if you can make that work with a filter, but I'm looking at other avenues.
Any procharger kit on our cars is a 1-off kit basically so I'm not sure what you are saying there. If I get the bracket made I could do an unintercooled kit VERY cheap. You wouldn't want to run a lot of boost unless you want to rely on meth (which I probably would), but on a stock motor you can't run much more anyway. I may still be pursuing the unintercooled kit because it SHOULD be by far the simplest and cheapest kit. I think you should do yours as well if you think you can.
This isn't the first time I've been in the process of fabbing a blower setup. I used to have a 96 cobra and judging by your name you know about the KB setup on that car. I was developing an intercooler for that setup and I was pretty far into it. I had an intercooler core and the intake was in the works. I basically just needed to take everything in to get welded. Then i got a new job, bought a H/C Z06 and sold the car
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Point is I love this stuff and making a custom setup
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#44
#45
Took a look at the CF thread....460 rwhp out of a Procharger starting at $7700? Hope these guys are not in business anymore, that's pretty pathetic. Another idea, you could get the small bore L92 heads and an F-body KB twin screw. Have not heard of any KB's on a V yet, there are a couple of Wipple's, but no KB's.
#46
BTW, just spoke to my fabricator and this is going to happen. I'm starting to look around for a blower. Haven't decided if I'm going to buy a new or used one. There will definitely be a thread for it and if it works out hopefully I can get him to make some extra brackets and I can sell those to anyone else who wants to do it.
#47
I read that thread over on CF and some of those people are those most mechanically idiotic people i have ever seen on a forum. Honestly they are no different the other people who buy expensive cars and have no idea how any of it works.
We honestly could thank them for the **** poor f/i market we have today with our vehicle. The one guy mentioning Chuck Mallet... haha.
#48
#49
its just a bunch of people with money to buy a vehicle, and not enough time to care how it works. or vehicles work in general.
Its funny how they always claim audi/mb/bmw owners act like that but our previous owners are worse since they never put the cash up for any of the things they tossed around back then. At least those other guys buy parts and push the envelopes.
#52
#57
congrats!
you have already seen this site right: this can answer alot of the little questions.. pretty sure he is using 103maf, 60lbs injectors and Boostapump.. but hit up ctsv154 or ichpen for what they are using as far as fuel pumps for the tvs2300.. there is a thread on cadi forums about the stock bucket and pump having a restriction. it some where in the performance section.
http://www.trafficjams.ca/Performance/Procharger.htm
this is ctsvmapper's procharger build.. check the FC1 procharge build on the cadi forums by spdracer77 something like that
#58
6-7 PSI is not too much at all...I would go with 60lb injectors, keep the OE fuel pump and add an external inline boost pump like a Walboro 255 (mounted where the fuel filter is instead of screwing with boosting the pump voltage, cheaper, more reliable, and much easier to install), and leave everything else OE. If you get up to or over 10lbs you will probably want to go speed density (2 BAR SD) with the tune, but otherwise, you're fine with the factory hybrid MAF OS.
*****MAKE SURE YOU HAVE A GOOD TUNER*****
#59
But, for your 6-7lb goals, If you don't wan't to drop the tank just wire up a boost a pump, add 60lb injectors and call it a day. BAP's only increase the voltage when you come into boost, so 95% of the time the fuel pump is running just like stock, which is nice because you don't heat the fuel or have the excess voltage of a second pump when not needed.
I think BAP's get a bad rap from people who don't ground them properly.
#60
Guys I have a problem. I got the blower all mounted up and I don't feel a difference at all. What could it be? bad tune? Should I pull the belt tighter?
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/422922_662577209811_51793457_n.jpg)
haha, jk. Got the blower. it will still be a little while cuz I have to save money for the rest of the parts, but this is a start.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
