Stuff for mah V1
I'm making a list of maintenance items for my V1 for the next few months.
I'm planning on doing the diff and trans mounts in the next week or two.
Did I miss anything? (Remember this is DD, the car has plenty power . . . for now
- 100K Maintenance Service
- CS Diff mount
- CS Diff Block
- CS Transmission mount
- LS7 Flywheel
- LS7 Clutch Kit
- LS7 Slave (Thanks wcryan)
- Pinion seal (Found grease on the exhaust shields this morning; have to check to see if was done under the recall)
- CS Motor mounts (when the current, new factory mounts fail)
- Shifter bushings
- PISNUOF Shifter
- Tune (also to turn the fans on earlier) (Thanks wcryan)
- Front Shocks
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
someone will chime up about a good tuner in SC
Also, you wont need the spacer anymore if you use the LS7 slave.
Read this thread. https://ls1tech.com/forums/cadillac-...-flywheel.html
It will help you save some money and also gives you exacly what you need to know. I guess SD parts has the whole clutch setup for like $495; which is a very good price
