Anyone experience this?
having problems with my LS2, every week or so the engine light and TC light comes on and goes into reduced power mode...please refer to this thread for full explanation...
https://ls1tech.com/forums/pcm-diagn...-time-ls2.html
Also, has any LS2 DBW cts-v owners cleaned out the throttle body and everything worked normally after cleaning it. Im not sure if cleaning it will give me more problems so i dont want to take the risk
This happened to me. There's a harness on the right side of the engine closer to the exhaust manifolds. Look for it, and make sure its very tight and or snug. Then, it wouldn't hurt to look at the harness going into the throttle body for a loose connection, then it becomes time to check your TPS and TB.
Go to advance auto and run the code scanner.
