Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
518 RWHP NA wasn't enough..... out with the old......
Old 04-09-2012, 11:58 AM
  #81
raven154's Avatar
Might as well cut a whole and grow a mullet lol
Old 04-09-2012, 12:37 PM
  #82
1BADCTS's Avatar
I would avoid cutting a hole... it's just not right!
On my Whipple kit, the stock hood has to be modified slightly to fit. But the EC hood was a direct bolt on with no modification to the 'inner' skin. Cutting the inner skin will buy you 1 3/8" of clearance at the snout area. I know because I'm looking for ways to get an extra 2.25" clearance so I can upgrade to the taller manifold.
So my plan is to cut the inner skin, fab some 1" cradle spacers and I should be OK (fingers crossed).
Old 04-09-2012, 05:30 PM
  #83
raven154's Avatar
1" cradle spacers? It's gonna look like a 4x4 when you get those in. I would just make lower engine mounts. I think the C5 mounts are about an inch shorter. There is also another company that makes some blower mounts for the GTO that lower their motor. The corvette mounts should work though.
Old 04-09-2012, 05:38 PM
  #84
1BADCTS's Avatar
No think about the suspension... Cradle spacers won't raise the car. If anything it might even lower it (almost negligibly I think). Ride height is set by the spring.
Old 04-09-2012, 06:29 PM
  #85
raven154's Avatar
Okay I follow since the top of the strut is attached to the body. Watch your oil pan. The only other isse I think I see is now the geometry for the suspension has changed. The upper control arms are attached to the body and and now the lower arms will be an inch lower. It may or may not affect anything but I would defineltly have the alignment checked afterwords.
Old 04-09-2012, 06:48 PM
  #86
1BADCTS's Avatar
You got it! Yes I thought about the suspension geometry changes too, so I agree an alignment would be a must. The ground clearance of the sub-frame would drop one inch, but that's no biggie... Same as installing lowering springs do.
The oil pan clearance would come into play if you tried to design lower engine mounts. I think youonly have about 1/2" to 3/4" between the subframe and the oil pan. I think it's all do-able!
Old 05-02-2012, 08:49 PM
  #87
southpaw0314's Avatar
any updates?
Old 05-05-2012, 11:34 AM
  #88
veee8's Avatar
Nothing new to update really. Still waiting on the short block.
I have spent hours trying find some kind of scoop/cowl to cover the blower. I just cant find anything that will look right. Then I dont know about the whole bonding fiberglass to aluminum deal either. Not like I am going to let it stop me or anything, beacuse I will just cut a hole around the blower and let it ride if I have to. (until a proper hood can be sourced)
Old 05-07-2012, 10:28 AM
  #89
TheLostDriver's Avatar
Haha nice
Quick Reply: 518 RWHP NA wasn't enough..... out with the old......
