Threw some codes
My 05 with 48k miles threw a p0171 and a p0174 left and right bank lean codes. I reset them and have put about 20 miles on since and they have not came back. Could it be a fuel issue? I run 91 octane. Only mods are cai and exhaust that I know of. I made an appointment to have the fuel filter changed tomorrow. Anyone else have this happen?
1 Post
Its probably CAI related. Make sure there's no leaks in the tubing, and worse case, it may need a tuning. I had this issue when I put on an intake. P0171 and P0174. I went back to stock intake until I can go for a tuning.
I get the same two codes - Randomly at best! I'll go for weeks without issue, then it will happen 3 times in a day.
Thing is, it only happens when the car is really warmed up, and at idle. Never when I'm moving.
My only mod is a Volant, and I figure it has something to do with the CELs.
The car runs and drives perfect.
Fuel filter is really easy to do & to get to. I wouldn't pay someone to do it.
It's on the passenger side frame rail, you'll need a set of fuel line tools (those little round plastic ones) but those are cheap.
actually, you only need 1 size fuel line tool, but they come in a set.
Thanks again. I have the tools but took it in to get it done and have the fuel system looked at. Seems to be running good. I have a couple hundred mile road trip this weekend so I will see.
http://www.youtube.com/watch?v=DKgQJ-RinXc
