LS7 clutch installed
I just got back from picking up by car with the LS7 clutch and flywheel. The engagement is definitely low to the floor, but honestly it's no big deal even if it stays there forever. I'm sure it will come up with time as others say, but I don't see what all the fuss is about. It feels great to me!
I will update this thread once I have more miles on it.
For me, "all the fuss" is about those who are reporting that their clutch engagement is so 'off' that they're unable to shift properly. I've seen reports of high RPM shifts becoming near impossible. That's a scary prospect for me.
Now, has anyone installed the LS7 slave with a spacer like the one you'd use if you had the LS6/2 slave? I saw "Fuzzy" post that he was thinking of having a custom 1/4" spacer made to use with his setup, but I havent seen anyone else that's used one of the spacers that are already available to us...
ive put about 100 miles on it so far. I dont know if im starting to get used to it. or it's actually coming up. But I think it is
during higher RPM shifts (havent gone that high due to break in period) I can feel the flywheel spinning through my clutch pedal a little. Hoping it goes away. Nothing that is undriveable or that annoying. But I can feel it
Shifting feels better and notchier; but in a smooth way
I'm up to 225 miles and the clutch engagement point has come up a lot, almost as high as stock if not the same. Engagement is smoother too, I love it. You do NOT need a spacer if you use all LS7 parts.
