drag wheels w/out tire press. sensors
so i did a search and didntt find a full answer. running stock wheels all around just bought 2 extra wheels with sticky tires w/ out tire pressure sensors.
problem is i cant disable all stability control with the tire pressure reading zero. sensors havery never really been accurate any way. so how can get get back the option of no traction devices with only the front sensors in?
I've seen people put tire sensors on non compatible wheels by using a giant host clamp around the center of the wheel to hold the sensor to the middle. So you could have one inside and one on the lip at the normal valve stem location. (Or 2 or 4 inside if you wanted.)
Short of it is they all have to be present and see pressure.
Disable: http://cadillacfaq.com/faq/answers/tpm/index.html
Disabling requires removal of all of the wheel sensors and should allow you to enter any traction/stability mode you wish.
The stability control system using steering position and yaw sensors to determine if the car is traveling in a controlled direction, but should not activate if you are simply driving straight even if you lose traction. But, if you were to lose control on the track and start going sideways, the stability control may actually help you out, and your run is probably f-ed at that point anyway.
One of these:
http://www.amazon.com/Chapin-20000-1...5915590&sr=1-1
Drill holes and mount the TPMS and then pump it up.
Love it...just love it.
i do more then just drag race. such as some fun freestyle type burnouts at car shows which would involve junk tires and the wheels with but sensors. can't do anything with stability control on.
im goin to try and remove all 4 sensors and just get rid of it all. anyone tried this from the cadillacfaq link that was posted?
That is a temporary fix which could work while at the track. Mine would re-register the good sensors after about 50-75 miles of driving and no longer could I turn the modes off. I would have to resync them to get the three lines
Since you are only running without two (I believe you said) eventually the computer will read the front two and disable the controls again.
^^^ Same here. I don't have any sensors and I can still turn off traction control, go in to competition mode and turn both TC and stability off completely.
That was meant to be posted below CancerJCC
