Am I the first to bust a trailing arm?
good luck on the freakin MAP failure....
Wow, no ****! That's some pretty ****-poor fabrication if the tubing isn't even recessed into the knuckle clevis.
I guess I should've noticed that before I installed them. Ah well... I'll have to find someone to strengthen mine, too.
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
Here's a pic of the aluminium bronze bushing a friend of mine made.
They supposedly have the same wear properties as poly but are more rigid.
Maybe too rigid?
There is no sign of them binding during suspension travel. I do have a set of poly bushings from TIC; I could use them instead.
I do think that the weld breaking was just from a shitty job; I figure the weld should be the strongest point if done properly?
Maybe too rigid?
![](http://i36.photobucket.com/albums/e29/tommycompton/2041f12c.jpg)
LS1Tech Premium Sponsor
I can't agree more, there was absolutely no penetration in that weld whatsoever. I am trying to get our R&D guys to redesign our trailing arms to allow more clearance for a bigger real wheel/tire so I hopefully I can make things happen for all you CTS-V guys here soon.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
#32
Have you considered redoing the toe-rods to make them easier to adjust as well? This has been the biggest thing keeping me away from them
#33
If you aren't going to re-design the toe rods, at least make a tool (sawed off deep socket with a lever welded to it) available to grab the inside nut.
Also, recheck the dimensioning of your parts (spacers).
I had to add fender washer shims to get the trailing arms to torque down without bending the frame.
Same goes for the tie rods.
