no fuel
well i went out to start my car this morning . it cranked over fine didnt start . so i checked the fuel rail no fuel , i cant hear the pump run either so i checked fuse and relay all was good . any where else i should look or try ? or should i just buy a pump ; and if i buy a pump what would be reccomended?
oh and its all stock with 66k miles
really not that big a deal to drop the rear and tank. you can do it in a weekend.
You need to check your fuel bucket at the electrical connection at the top. the older V's are starting to have this problem.
you can do it without the tool. BFH and screwdriver. Even the dealer told me to do this when I asked about the tool. he laughed.
with the tank down you can do this.
I cut my own service hole when I installed the Racetronix kit (includes Walbro 255LPH fuel pump). You don't need a special tool to remove the ring (just hammer it around with a pipe and big freaking hammer), but you'll pay the price in terms of the installation being a ROYAL PITA.
Recommend checking your fuel filter first. If you unscrew the outlet fitting and fuel doesn't come out, that means that you've got a dead pump.
