Car won't start
Car won't start
Long story short I picked up an 04 V from a buddy of mine on a steal, just got a fresh ls6 with a 228r put in, at first the car did not have any power, found a blown ignition fuse and power to the car was back on.
The car still did not turn over, took a look at the starter, the starter was good, brand new and tested out fine. The car will start with a push start and run/drive fine. But cannot turn it over with the key itself, figured it may be a bad ignition switch replaced it today and still won't turn over. In looking around today i found a 5 pin connector on the side of the steering column that is not plugged into anything and an open hole where it looks like something to be mounted. I can't find anything as to what should be there any ideas? or any other common issues people have come across in ignition?
Any help or input would be much appreciated. Thanks
I had a major problem with getting my car started a while back, had power but wouldn't crank. I replaced the ignition switch, relays and checked fuses like 10 times. Finally I traced it to a loose connector behind the passenger side dash which was the connector that ran one of the the 2 ignition wires (both must have power to crank) from the fuse box on the passenger rear fuse panel. The connector has a big white plug, make sure it's seated all the way, you can access it from the side access panel of the dash.
If that's not it, here are the wiring digrams for the ignition switch and starting system. Have you tested to ensure you are getting full power at the starter?
Starting
Ignition Switch one
Ignition Switch two
Starting
Ignition Switch one
Ignition Switch two
The connector i'm referring to is just left of the steering wheel and I attached it.
I'll check that, the wiring was just redone on that because the piece did crumble. What ends did you put on it to get it to seat properly??
i bought the pigtail from the dealer..cant remember the part number but its the single wire weatherpack connector that goes to the starter. its the signal wire for the starter to engage. ill try to find a pic of what im talking about.
if u get under the car and look at the starter youll see what im talking about..either the connector is junk or the wire is shorted somewhere right in there..its a common problem
