Widening stock wheels and running MAP trailing arms. Couple questions...
When widening the wheel, the face of the wheel is not affected right? Just wondering if I should send them to be widened now before I send them to Powdercoat or if it really makes a difference? I assume the section that will be widened won't even be seen anyway so I'd assuming coating now and widening a little later if I decide it's 100% necessary would be ok right?
I was all about widening but now I'm thinking I wanna get the car lowered and see the stance on my current 275/40 and 255/40 combo at stock width. 10" in the rear would be nice but spending $500 plus shipping fees both ways just seems like a healthy amount considering I'll only be able to run a 295/35/18 out back.
I would get them widen 1st before you send them out for poweder coat. They might f-up the surface on accident when they weld. I think you can run a 305/35/18 on the back with spacers. I am running 10in wide 295/35/18 w/ GC (lowered) with out spacers. I plan to put a set of 305/35/18 MT drag radials on this week w/ 5mm or 10mm spacers.
I do have MAP trailing ARMs, widen accessory wheels and longer wheel studs.
Ok. Let me know if the 305 fits with the spacer. If it does, I'll prob go ahead and widen them after all. And post pics please!
I bet the widened accessory wheels look sweet.
I took my wheels to Powdercoat today to get them done semi-gloss black. Ill have them back next week. Gonna get the car lowered on those first and see where the stance is clearance wise on the current 275/40's. Then I'll still have my 4 extra stockers to mess with. Perhaps widen a pair of those and coat them too when I'm ready or just throw a pair on in stock form temporarily while I send the black pair off to be widened. Either way, my Powdercoat is a quality job and the guy hooks it up for cheap. Just don't wanna spend the $700 it's gonna cost for widening and shipping the pair both ways at this moment but prob will soon.
#33
By the way, here are the old pictures that I posted comparing clearances between the stock trailing arms and the Killernoodle trailing arms.
Splitscreen
OEM trailing arm
#35
"Puff Puff Give"
My setup is different from yours. I'm running MAP trailing arms and widen stock accessory wheels to 10in. I think your wheels has a different offset than the stock wheels. I will try to get some pics when I have time.
#36
I got an update. I widened mine to 10 and put MT 305/35 18s on them. No rubbing with MAP arms. Im not slammed though. Just 1.5 lowered
