D2 Coilovers
#61
Has anyone ever truly figured out if the rear shock towers are actually safe being load bearing for a coilover setup? Has anyone ever had any failures in that area? After all, that spot is just sheet metal meant to support the load from a shock, not the weight of the car.
Just curious, I'm interested in getting a set of D2/Ksport.
#63
I have the D2 kit sitting in my garage that will be run in a 4 corner soilover setup but have more pressing issues to tend to as my first track day cause my radiator to puke its guts.
#64
#67
The rate of motion is different between front and back(affecting the amount of spring rate seen by the wheel) so even though the rear is using a stiffer spring the wheel rate will be higher in the front of the car due to the extra leverage created by the spring position in the front suspension. I don't have the exact numbers but most spring kit's available for the V1 come with a higher rear spring rate or equal at all corners. However the kw v3 kit does not follow this rule and comes with a stiffer front spring but some including myself have opted for stiffer rear springs when using the kw kit to balance things back out.
If you moved the rear spring from the control arm to the coil-over location the rate of motion in the rear suspension would increase and running a stiffer spring in the back may not be the ticket.
#69
what garrettg said. to get the wheel rates to be similar the rear needs to run stiffer due to the spring being significantly more inboard in the rear than in the front.
If you move the spring to the shock/strut mount, you need to significantly reduce the spring rate by as almost 50% to maintain the same wheel rate.
#72
#73
Not sure if this is correct or not, but I'm running KW Variant 3 suspension and hotchkis sways no problems here.
#74
I got this off of cadilacforums.com here is the url
http://www.cadillacforums.com/forums...coilovers.html
#75
[QUOTE=Dmax/04V;16873118]Not sure if this is correct or not, but I'm running KW Variant 3 suspension and hotchkis sways no problems here.[/QUOT
Yes KW's do work with the Hotchkis kit.
I'm trying to figure out if id be better buying QA1's with my H&R springs and get the hotchkis sway kit if the D2s and ksports are unable to run aftermarket sways.
#76
Hotchkis sways are a huge improvement, you need adjustable endlinks with them. I spent the money and got powergrid ones which I am very happy with. I still need to roll my fenders with stock 245/45/r18's, because of my ride height. Also going to switch to a slightly lower profile tire and run 255/35 front and 265/35 in the rear.
#77
#78
[QUOTE=Onefast V;16876838]why do you need adjustable endlinks for springs? and do you guys think d2s have the capablity of running hotchkis sways? plz someone with d2s answer this question because if they can't then im going h&rs with QA1s and hotchkis sways I'd spend more that way but I reall want the run aftrmarket sways to eliminate as much roll as possible.
#79
