Lingenfelter CAI poor fit on 06 V
#41
1. Just be glad it is not a Volant!
2. OP, yours is clocked differently than everyone elses, from what the pictures show.
3. I agree that it looks like your front end looks tweaked from an accident.
a. Carfax does not mean **** if the person that wrecked the car did not have it fixed by insurance or a body shop that reports.
b. There are body men out there than can make an accident go away to the untrained eye.
4. Do you think you can get some measurements inside the box to see if the box is indeed tweaked.
5. Have you replaced your motor mounts?
6. Just be glad it is not a Volant!
#42
I'm surprised so many people run the lingenfelter intake. Not trying to knock it if there is an advantage to it that i dont know about but it looks like a slightly bigger/better but very similar barrier and filter combo than the K&N and doesn't even include an intake tube (unless they now include one with it). Someone please tell me why this intake seems to be so popular.
Like I said, not trying to ruffle feathers... I just don't get it. I went from my K&N FIPK to the Volant for the fact that it's a sealed intake box keeping the filter concealed from the engine bay heat. That to me makes sense as an upgrade over this style intake.
And 54... Why the hate on Volant? No issues here with mine.
#47
The Lingenfelter airbox seals really well. The Volant airbox reputedly heatsoaks like nuts. Another problem is that the best tube that you can drop into our cars is the Volant tube, which only measures about 2.75" ID. Don Kinder (owner, Slowhawk Performance) thinks I'm leaving significant meat on the table with the Volant tube and recommended that I source some larger piping ASAP.
#49
#50
Lol @ 54!
With the LS6 TB being just 78mm stock... Even ported, i would think the Volant is plenty. Maybe u LS2 guys running the 90mm setup stock are closer to being maxed out with the volant tube but i doubt it. If that really is an issue, i may look into a custom intake tube setup similar to the JLT intake i had on my 03 cobra when I go 92/92 but for now, I don't think the Volant is hindering me in any way. I believe the stock mass air is 85mm correct?
#51
Probably. The MAF is 90mm, which is 3.54". I'll have to decide between 3.5" piping and 4" piping with reducers for my application.
http://www.siliconeintakes.com/
#53
Sorry to bring back a dead thread, but back in Post #16 (see picture below), ShadyLS6 identified that he removed the outer baffle from the original airbox to give himself more clearance. I was thinking about doing the same thing and putting a significantly larger filter in there to match my new 4" intake tubing.
![](http://i549.photobucket.com/albums/ii384/shadybx7/IMG_0268.jpg)
Anyone have advice on that baffle removal process, or should I just wing it?
Also, does anyone know where to pick up new rubber gasket material? I was thinking about putting something beefier in there to try to achieve an even better seal.
#54
next step with a setup like this is to redirect the Driverside brake duct up into the CAI chamber the LPE creates. I have a solid dent in the hood insulation from the outline of the LPE plastic. so it would deff add more clean air.
i got the rubber gasket pictured above from homedepot back in 08. i think it was originally window weather stripping.
descreen your maf before the tune? i did it right before i got a street tune, no more Maf bottle neck tuner. IMO is overkill without intake and heads but its possible i think CTSVoodo on cadi fourms did a thread while back
#55
There is no screen on more recent Gen III (LS6) and all Gen IV (LS2 and later) MAFs. I would never redirect brake airflow to the filter. The brake cooling ducts are there for a reason, and the benefit you'll get out of doing that is minimal. I'd rather concentrate on ensuring that I'm not sucking hot air out of the engine bay.
Thanks for the feedback--especially the part about the adhesive. I'm wary of yanking on something if it's stuck and I don't know why. The last thing I want to do us yank out a bolt or rivet and damage something else.
I'm also working with GT|Motion on the Cadillac Forums to figure out how to better insulate the bucket.
#57
maybe i wasn't clear about what i was talking about.. JCC type of setup looks like it would lower IAT in general. IMO the more fresh air inlets for the CAI the better.
http://www.cadillacforums.com/forums...well-pics.html
#58
![](https://i98.photobucket.com/albums/l261/JonCR96Z/DSCN0258.jpg)
#59
I thought I would report back for the sake of completeness, because i hate unresolved threads. I finally got around to removing the plastic baffle against the body of the car, and now the filter fits perfectly in the horizontal position, with about a half inch of wiggle room. My guess is this will be necessary on all the 06-07 cars.
#60
