Lets talk clutches!
I'm a relative newb to the CTS-V owner world, didn't have mine but for a few months before I deployed to Afghanistan. I'm looking into some reliability/performance mods to order when I get closer to going home. I see numerous people running the LS7 clutch kit in bolt on cars and they love it. Anyone running it in a cammed car? If so, how is it holding up? Any problems with it?
I will be running the EPS 222/226 .596/.598 112LSA thats currently in my Impala SS (the Impala will be getting the 226/234 .605”/.612”) if that matters. I'm waiting on a response from Creative Steel about the 8.8 kit, as I already have a line on a center section out of a Cobra, seeing as my stock rear was already leaking when I left. Any help would be appreciated.
That works for me lol. I know SDPC has them, are there any other places you recommend? I've read that some people used the slave cylinder spacer, some didn't. Any particular reason that you would know of?
NeverSatisfied (withhisexhaust) How do you like the Ground Control kit? How does it ride? I'm not looking to ride ridiculously low, just get rid of some of this damn fender gap.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Sounds like my best bet is either the LS9X/R or the LS7. Where's the best place to get them? I know Katech has the LS9X/R clutch setups, but who sells the LS7 besides SDPC?
edit: Thats one hell of aprice difference between the LS7 and the LS9! Shat!! Good thing I'm saving my pennies.
Bud, that would explain it. I think I'm gonna have to stick with the LS7...I don't think I can justify dropping that kinda coin on a clutch...I feel that money is better served in the CS 8.8 conversion.
The GM LS7 clutch is available on eBay for $300:
http://www.ebay.com/itm/New-GM-LS7-Z...#ht_500wt_1180
There's a version with the matching 25 lb steel flywheel for about $500. The whole assembly like that weighs 57 lbs. Personally, I'd recommend avoiding that and getting an F1 Racing (20.4 lb chromoly steel--$220) or Fidanza (13 lb aluminum) flywheel. If you want to buy my old F1 Racing flywheel, send me a PM.
Edit: I just found out that F1 Racing is now selling five complete kits with a powdercoated LS7 pressure plate, friction disc, 20.4 lb chromoly flywheel, replacement pilot bearing, 26 spline tool, and what appears to be a PowerTorque CS2529 LS7 slave (which I've been beating the snot out of for the last 15,000 miles). DAMN IT! I could've saved a buttload. Depending on which friction disc you choose, these things seem reasonable:
Level 1 @ $585 (good for 565 HP / 510 TQ)
Level 4 @ $645 (good for 660 HP / 610 TQ)
Level MF @ $659 (good for 625 HP / 578 TQ)
Disclaimer: I haven't tried any of F1's pressure plates. Anyone try one of these?
Fawk! If only I could look at Ebay from work! I'll check those out when I get off.
Is your flywheel the same as the one in the kits you listed? It wouldn't hurt to have a spare I think.
I don't see any mention of the spacer that I've seen floating around. Is that only if you are using the CTS-V slave?
Here's a picture of the Stage 1 clutch in case you can see it here while you're at work:
My clutch was $799. Holds 700HP. No chatter. Pedal feels very close to stock. I wouldn't dismiss diamond as an option if you want a bad *** clutch without losing any drivability.
I'm putting the rear in for insurance. Just in case I do decide to launch it one day, I know the rear is the least of my worries. I'll look into Diamond too Neversatisfied.
Luke @ Lindsay Cadillac has the full LS7 kit in stock for a pretty good price. Also if you go with the LS7 Slave you won't need a spacer.
Be sure to pick up a remote bleeder from Tick Performance while you're in there and may as well add some ARP flywheel and pressure plate bolts for good measure...
I went with an Exedy for full time track duty
![](https://lh5.googleusercontent.com/-QJASp7CEnMA/T60znkN9KGI/AAAAAAAAA6E/3mhMAz-N__o/s800/IMG-20120510-00054.jpg)
![](https://lh6.googleusercontent.com/-psL0kR8PhVU/T7Ko5hB5TdI/AAAAAAAAA7c/P-wbOqwQNz0/s800/IMG-20120515-00061.jpg)
