why such poor 60's in time thread?
Are the rears as bad as 10 bolts? I'm purchasing an 06 in the next couple days, the 8.8 conversion and a tire will be my first more if that's the case.
Also I haven't seen anything, but do I need to pull the stabilitrak fuse as well...I know it helped slightly in my TBSS.
I was just hoping these cars would do 1.80's out of the box...not 2.0+
^^what he said
I got consistent 2.0's launching from idle, as soon as I tried a harder launch from 2500 rpms I wheel hopped and broke an axle cv joint. I have no wheel hop fixes, so that's pretty much what you can expect unless you build the rear end.
I beat on mine. I have DSS 1000hp axles only and frequent the dragstrip every chance I get. have a full kars kit III sitting on the floor of the garage.
I am pretty sure one of the fixes for shattering rears is when it starts to hop, let off the gas!
I definitely believe the axles help the harmonics and keep the hop away. Not 100% though.
No way to really describe it but I assure you the first time you launch it you will see what all these comments are about. This car is a beast at 2nd, 3rd, 4thgear pulls but off a dig launching it makes you cringe...you can feel the pain your car is in!!!
Next stop was a 9".
the stock diffs are junk.. i broke my original,,then two cv's (one with a stock axle and one with a g-force) and cracked a gen4 diff. when i pulled the gen4 i found the back lash was almost triple the max. the case is still in one peice but deff wore the pinion out. im pushing close to 500whp.
even from a second gear pull the rears after some time just cant take it. even with no hop. the gforce axles took about 80% of the hop away but still broke.
Definitely a weak link back there...I have a gen 4 diff in my car and the wheel hop at the track last weekend killed a cv but left the diff intact. I'm at 450 rwhp and I'm sure it was just going to be one or the other and I got lucky.
the cast AL case is the weakest link then CVs inner/outer then center drive shaft bearing.. the area around the pinnion is the weakest and the pinion slop is built in to absorb some of the force..
![](http://i2.photobucket.com/albums/y14/Stone17_2/Rear.jpg)
even the Solstice diff is stonger than a stock ctsv1
![](http://image.hotrod.com/f/projectbuild/8923223+w794/hdrp_0605_solstice_differential_17_z.jpg)
Okay that's a little better, for 4600 it was sounding like I was still going to be breaking things back there...
