SMFH...Changed slave, needs master LOL
Welp, as the title states. DOHHHH
Had some hydraulic issues lately. Obviously 99/100 you will have a slave concern.
Now the replacement wasn't useless. The clutch turned out it didn't have much life left in it so that's a bonus.
Plus, my driver side header rubbed a little on my steering rack so I heated it up and fixed that issue.
However, got everything back together and for 45 minutes tried bleeding the clutch and cannot get a firm pedal. I then borrowed a mighty vac, and tried to power bleed it with this, and same concern cannot get a firm pedal. I guess that leaves the only other possibility the clutch master.
Looking at it: I think I'd rather change the slave 10x before I have to change this![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Never any luck
Another bonus:
I found my ECU cover was missing, and the ECU was ready to fall the F out to the ground
All in all some benefits have come from this.
Never any luck
Another bonus:
I bled the hydraulic system on my 93 Chevy truck with compressed air. On that truck the master is on the drivers' side and the slave is on the passenger side with a hose that has several bends. A real PITA. I took a lid from a old clutch reservoir and cut a hole in the center of the rubber. Next I had a friend get under the truck and crack the bleeder then I used a blow gun while holding the lid on with my hand I put a little air pressure (20 psi) through the top vent hole which forced fluid out the bottom without pumping the pedal and aerating the fluid. Worked like a champ.
Keep bleeding with the mity vac. it took me FOREVER to get a firm pedal after my clutch/slave install, i probably bleed it for 1-2 hours with the mityvac then it finally got a pedal. it took far longer than i ever thought it would.
make sure you are watching to make sure you don't run the reservoir dry, it is easy to do with a mity vac (and even regular bleeding) and will start your clock over.
Some people have had good luck with the bleedign and it goes quick, but sounds like your car may be like mine.
there is no "clutch cable", it's a hydraulic line.
the master really isn't hard to do if you're patient (which i'm not, i had brian come help). Unclip it from the pedal, pull your coolant surge tank over the brake master, get your hands in there, squeeze and turn about 3/8ths (i think) of a turn, and pull straight out.
Radeon, how long did it take you?
Also, I did try bleeding with a MightyVac for a little over an hour, and I get absolutely no pedal. It is straight limp lol. It doesn't get any pressure.
