Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Revshift install
Old Jan 15, 2013 | 10:51 AM
impulse27297's Avatar
Default Revshift install
Well my parts finally came in and I have off all day tomorrow. Going to start off with my MM's and trans insert. Then, maybe depending on how long that takes I might go ahead and tackle the rear end with the cradle, diff, and trailing arm bushings.
Any help or pointers will be greatly appreciated!!
Old Jan 15, 2013 | 11:46 AM
NIKDSC5's Avatar
sawzall is by far the cleanest and easiest. Just cut out the rubber and then the metal ring. I used just a hand held propane torch and heated up the outside of each sleeve good and hot then beat out the rubber. After words I used an air hammer to get out the ring. If you plan on using a torch there are a couple of things I cannot stress enough, gloves hot sticky rubber does not come off-along with clothes. A WELL VENTILLATED AREA! The smoke will be plentiful. Once they are out people said they tapped them in....yeah...I couldnt. So I used a large C clamp and essentially pressed them in. Went in like butter. Trailing arms are the same story, and I neved did the diff. Good luck!
* I also did this with the diff out of the car and lowered the cradle to the floor with out disconnecting any brake lines. I had it all apart!
Old Jan 15, 2013 | 10:11 PM
xbladr's Avatar
I did not use a cclamp for the bushings however i bet it works great. I pressed them in a little by hand then a couple wacks with a rubber mallet and in they slid. If I couldnt get it completely in (the top halfs) I found it was close enough to use the bolt with washer to press them in. In terms of removal I drilled around the rubber then sawzalled around the center sleeve. After that I was able to sawzall the outer sleeve then air hammer the ring. Plenty of lube and it slid right out.
I will be tackling motor mounts next as well. I am hoping it goes pretty smooth as im still stock headers.
Old Jan 15, 2013 | 10:14 PM
54inches's Avatar
Take pictures!
Old Jan 15, 2013 | 10:18 PM
Mrs.LS6's Avatar
I think revshift posted a tutorial on the how to on their page. They used my car to design all the mounts and bushings and took pictures of the entire install process.
Old Jan 16, 2013 | 04:42 AM
odthetruth's Avatar
Revshift trans mount:
https://ls1tech.com/forums/cadillac-...nt-review.html
Revshift cradle bushings:
http://www.cadillacfaq.com/faq/answe...all/index.html
Follow the words, not the pictures for the cradle bushing. Don't remove the whole bushing or remove the bolts, just loosen it so you have space to play around, otherwise, you'll be under there trying to re-align ****. LOL
Old Jan 16, 2013 | 08:07 AM
NIKDSC5's Avatar
That link is not for revshift cradle bushings. Those are spectre works bushing inserts. Revshift is a whole new bushing, not just an insert. If you can change the bushings with out removing the whole cradle (or at least dropping it down) and just loosen the bolts, then you are a better man then I.
Old Jan 16, 2013 | 09:51 AM
About to start within the next hour. Wish me luck!! Haha
Old Jan 16, 2013 | 04:21 PM
54inches's Avatar
TAKE Pictures!
Old Jan 16, 2013 | 04:57 PM
DMM's Avatar
DMM
That's pretty awesome. I went the sawzall route for the sub-frame bushings...make sure you use a corded sawzall, and use a very rough tooth blade (wood is okay, I used a pruning blade) as it gets through the rubber faster without clogging. After that, use a metal sawzall blade to cut one line through the length of the metal bushing body and it'll damn near drop out.
Trailing arm bushings come right out with a two jaw puller.
Good luck!
Old Jan 16, 2013 | 05:06 PM
Mrs.LS6's Avatar
Good luck!
Yeah minus the fact of missing my car for two months while they designed/fitted all the bushings, it is very awesome! The car handles like a completely different vehicle. I'm VERY pleased.
Old Jan 16, 2013 | 05:14 PM
serik21's Avatar
Dmm did you drop the subframe all the way or just one side at a time ?
Old Jan 16, 2013 | 07:08 PM
DMM's Avatar
DMM
I took it all the way down...I am fortunate to have a lift and pulled the fuel tank at the same time to install a DW300. If you use the sawzall, I found it to be easier to access from the top...and I did try from the bottom since the subframe was on jack stand's.
Old Jan 16, 2013 | 11:47 PM
serik21's Avatar
i have access to lift as well but its the kind, where you ill owe the person a favor and i try to avoid it if its possible lol. but i might as well do that if you say it will be a lot easier
Old Jan 17, 2013 | 08:12 AM
Well, MM's and trans insert is installed..
Sorry I didn't take any pictures. The MM install went really smooth, I watched the video CS put on Youtube. Which knowing the proper extensions and the right size sockets right up front always helps speed up the install. Also after I pulled out the old MM's I noticed they looked new. After looking at the warranty sheet from when I bought the car I noticed at 72k they were changed, but I did notice a change. Barely any "diesel shut-down" and the car feels to have more raw power.
As for the trans insert. It was a bit tricky, but between wd-40, soapy water, hammer, pry bars, and a c-clamp it finally popped into place "without removing cat-back". My only concern was when I was wedging the insert in a few small pieces of rubber from the oem trans mount cracked and fell out??
Sunday I will be installing the cradle, diff, and trailing arm bushings. Out of everyone who has done both mm/trans insert and the rear end bushing swap what do you think would be considered the easier install?
Old Jan 17, 2013 | 08:28 AM
NIKDSC5's Avatar
Um...the trans insert by far the easiest. Captain obvious is alway free of charge!
You will have to remove the exhaust to do the diff bushing and cradle bushings....so I would say the MM were easier for me. Especially since I had the exhaust off for them before installing headers.
Old Jan 17, 2013 | 08:36 AM
Onefast V's Avatar
I would Say MM are probably the hardest simply due to space constraints then rear cradle bushings and trailing arms.
Old Jan 17, 2013 | 08:43 AM
I was meaning MM's and trans mount as a "package" install together. Obviously the trans insert was the easiest!! HAHA
Old Jan 18, 2013 | 02:50 PM
xbladr's Avatar
I would tend to think MM would be easier then rear cradle just because of the time and patience it takes to do the rear cradle bushings. It is non stop drilling and cutting and pulling and drilling and cutting and pulling. Then you need to press them in. Granted I have yet to do the MM doing them soon but, i have a strong feeling they will be much easier for me. I have a lift in my garage though so things always are a little different for me.
Old Jan 18, 2013 | 03:04 PM
FoD's Avatar
FoD
...And where are you at?
I'm doing the Diff Bushing install either this weekend, or Tuesday. I've had the MM and Trans insert installed for a while now. Vast improvement! I will also be installing my new GForce 2-Piece Driveshaft so I can get rid of that infernal screeching center bearing! Clutch install shortly after.
