Bad Damper Symptoms?
If an OEM damper is bad, is the vibration felt during a neutral rev AND when revving up under load?
Is it possible to be perfectly smooth in neutral (or w clutch down), yet bad vibration in gear accelerating under load?
Is it feasible that it could only show symptoms when engine is under load?
Per my other thread, new engine, newly rebuilt trans, good diff, new driveshaft, new mounts, dual mass flywheel replaced with a balanced LS7 clutch. Noise is in sync with the flywheel side of the trans. Dampener is literally the only possibility left, but just confused why it the noise/vib would occur under load.
Could be power steering pump, alternator or even A/C compressor (even if off).
How bad are we talking? I had a very similar pattern of symptoms. It was certainly engine related but seemed to be more in rear the clutch...it vibrated bad. In neutral, under load, whatever. Seemed like an oblong/egg shaped orbital up/down vibration.. My hand would go numb on the shifter, the rear view mirror looked like I had 18" subs in the trunk.. my headrest shook and the passenger seat even wobbled as I drove.
I recently replaced my stock balancer with another stock unit to rule it out before I went after the clutch. The one I replaced had <10k but still seemed to visually 'wobble'. The new one does the same thing, and I followed the install instructions to the tee using the right tools. Prior to the balance install I also pulled my mounts to rule them out as the culprit. Lastly I removed the accesory belts and cranked it just to be sure..
I just replaced the clutch with the ls7 setup. and the vibration is gone. I noticed before removing the old setup from the engine that all the fingers on the old pressure plate were bent bad outward much more on one side than the other. It could have been that I didn't torque all the pp bolts down the right way last time, and/or the fact that I reused the stock bolts and not enough/or too much red loctite. I'm guessing it was (not only that POS flywheel) the pressure plate not working correctly.
I know you already have the LS7...so could be a botched clutch install? Thats my only guess unless it's something accessory related. The vibration in neutral rules out everything south of the trans.
