Having brake problems please help!!!!
Sounds like your having the same problem as me... do you think it would have something to do with the brake lines or there is just a lot of air in the system
After reading all these brake problem threads surrounding goodridge lines....The way i intend to install them is one at a time. Starting with LR, install, bleed. RR Install, bleed. RF etc etc. Then, you guessed it, Beed it all again! Never let the master even get close to dry!
Good luck OP!
Good luck OP!
If the brakes are hard to press with the motor off, and easy to press with the motor on the brake booster is working exactaly the way it was designed. His brake booster is fine. He needs to rebleed the brakes.
Look there is alot of air in there, keep it up and it will get better.
All that said, I can't hear the noise he's speaking of, so for all I know, there could be brake fairies down there hissing because they're tired of helping him push the brakes after so much bleeding.
Every set of power brakes I've ever used makes a slight hiss when you initially step on the pedal. Both sides of the diaphragm are under vacuum before you step on the pedal once you depress the pedal a valve opens and you can hear a hiss of air rushing into the cabin side of the diaphragm using ambient air pressure on one side and vacuum on the other to help force the pedal to the floor.
Is this not how a vacuum booster works?
Once again, I can't hear the noise myself. Why would he mention the noise if it had always done it? I've replaced quite a few on customers cars for this problem. I guess there's no possibility of me being right. I concede.
Your acting like I was being immature or rude when you make comments like this one?
Is it possible the booster is bad, sure, but if the pedal is hard to push down and the motor is not running lean, I would say its unlikely. I will gladly accept your concession of defeat though.
fn goodridge... Who has goodridge and DOESNT have issues? I'm just curious..
I had my wheels off the other day and noticed the LR line had dirt coating on it similar to a coil spring that gets oil on it...but couldn't see any visible leak.
I might replace all my crush washers.. that might help.
My pedal has gotten much softer in just the past week so it's time to bleed. again.*sigh*. I remember when I could breathe on the pedal and it was like a brick wall...
as far as the sound everyone is talking about, I certainly hear the standard 'whoosh' or 'shhh' as I press my pedal right now...not so much a hiss you'd hear from a leaky booster though. Everyone might be talking about the same thing here...plus wouldn't a leaky booster create a stiff pedal?
As a benchmark of air in the system, once you turn the car off, how many times can you guys press the pedal before it gets firm? I'm up to about 15 good strokes.
When I'm driving I don't get any pedal until about halfway down.
if it's firm like good brakes should be and you aren't stopping, especially in the V, I'd call that a shot booster...even though it's a rare failure.
Good luck OP!
Good luck OP!
I think some people don't start listening until there's a problem...then sounds that have always been there become the "issue"
#34
The bleeders are on top of the caliper and now I'm confused do i have a bad booster or not or just a leak some where keep in mind the pedal is really stiff with the car off but when the car is on and booster is working the pedal goes straight to the floor and the only way I get pressure is by pumping the brakes 5 or 6 times and I lose the pressure rather quickly and if I don't pump the brakes and I just slam the pedal to the floor I barely stop
#35
The booster won't cause a loss of pressure. If your losing pressure while holding the pedal down, something's bypassing (master cylinder or abs unit), or something's leaking. Pull the boots back from the caliper pistons, and check if it may be leaking but not making it past the dust boots. Another thing to check would be the rear of the master cylinder. Sometimes they'll leak into the booster, and you'll never see it.
#37
those hooks are the key... I made my own using a garden sprayer and a tire gauge.. but I use c clamps to hold it down. works like a charm but doesn't get the air out.
my next rig is going to be a retrofit of my mityvac.... I'm gonna hook up my shop vac to the line in place of the hand pump....
#38
I only had one problem with the install, but once I got that sorted out they work great. My pedal is almost too touchy! Buy some rubber vacuum caps at the parts store and as soon as you take the rubber line off, cap the hard line so you don't lose any fluid. I never let my master get anywhere close to dry and bled them according to the Faq.
#39
#40
