Anybody running 275s?
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
![Gruffy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_gruffy.gif)
What are you talking about? I have contributed so much to this thread! So much knowledge! As much as a search engine can contribute= alot!
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
At any rate relax. You got your answers from others, just like I did when I bought my 275's. Best of luck with your V.
Thanks for your contribution. Any other bits of knowledge for me???
I should probably add that I am on my phone and had trouble finding the photos I was looking for.
I have found people running 35 and 40 sidewall. The kdw2 seems to have a little thicker sidewall than my previous tire. So I guess the 35 would be better maybe.
But wait for it as there is some coming.....
This.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
How is this for contribution?
I like Continentals.
You are welcome. um, I am not providing any more info that is searchable.
This.
I can search with my phone too!
Nope, I can run 275.40.18s ROUND and nit rub anywear. It's hard to drive on square tires.(I don't think that is searchable, but general info that any caveman should know.)![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Believe me Nancy if there was a Suck button we would have pushed it so many times on this thread, it would have sucked itsself into a black hole.![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
This.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Alright so I still haven't bought tires yet so , was going to do the staggered fitment of 245/45 and 275/40 but now I see that 275/35 fits all the way around; would like some opinions on which way to go
Depends on what you use the car for? If you track or autocross then yes definitely go 275/35 due the higher grip limit up front. If its just a street car I really don't think you will get much out of 275/35 all around except spending more. A good tire will have more than adequate grip on the street with a 245.You have to consider your application.
I wish I seen this before 2wks ago. I bought 255/40/18 all the way around thinking that was cutting it close (stock height). I've got like a finger or two between the wheel/wheel well.
Thankfully TireRack caught my mistake as I had selected my car, but manually picked 17" tires! They called me & fixed it.
#33
Didn't really see anyone in this thread say anything about H&Rs w/MM spacers. I'm do for new rubber so I am debating on to setups. 245/40/18 Front - 275/35/18 Rear Or will I be fine doing 275/35/18 @ all 4 corners?
#34
The front should be fine @275/35. I would be more concerned with the rear.
#35
Eastern Regional Coordinator
im not going to add to the SEARCH NOOB of this. But niether am I posting pictures of my car.
Which has had 275 18 and 19s. And had to roll the fenders lowered on linea corse 19s with 275 35...
#37
sadly. I did with my jack handle in OC. put 4 people in my car. Cut tire BAD. 560 dollars for 2 new rears(FYI finding 19s in OC is a PAIN IN THE ***). And ghetto rolled them for safty. Going for a full roll and slight pull before spring. want to get 285s on.
#38
Got this backwards. The rears have new major issues running a 275/35 or 40, outside of getting a little rub. The front will have serious issues, especially when lowered, if you got wider then 255 (maybe 265). The issue will be made painfully obvious if you hit a bump with the wheel making a moderate to faster turn.
#39
