fastest V1 1/4 mi pass?
#61
I am not hating. Just saying. The fastest drag radial LS powered car is IRS. Just saying for the kind of ET's your talking about you really don't need a solid axle. http://www.youtube.com/watch?feature...v=viklTTmIcjI#! to each his own
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
#62
So your saying manual valve body autos are manly and as long as it doesnt shift by itself its ok? Im not quite understanding your logic, but I want to get your approval so I can sleep at night. Obviously your out to prove something so make some passes with your man pedal then return with the results. Your looking at setting a record but havent even made a pass yet have you?
Not trying to set records with my family sedan lol just proving a point, Most of the fastest drag cars/racers in drag racing prefer a GEARBOX. Not sure where you got the manual valvebody assumption, that would be relative to an AUTOMATIC. All the cars I mentioned have a gearbox, not an automatic.
Are autos fast? yes. Is it easier to go fast with an auto? yes. Is there as much driving involved in an auto as there is a manual? No. Ive driven a high 10 sec n/a camaro with a 4l60, and after the converter hit it was the most boring 10 sec car ever. I've also driven my old low 11 sec camaro that was a stick car. it was a handfull compared to the 10 sec auto car. Hell even my fiance's 12.20 daily driven 6spd gto feels a bit more rowdy down track than the auto car. Do I prefer a manual? yes. Is that the point I was trying to make? yes. Can you go fast with an auto maybe a bit easier? yes. Just not my cup of tea and among REAL drag racers not as respectable IMO, but to each his own. The end.
Back on topic, I didnt start a manual vs auto benchracing thread, just posted a simple question.
Cheers to all that hope to get some v1's a bit higher on the list, best of luck to you all! Mine will probably not get there because I'm keeping my man pedal
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#63
dude will drive the car to the track, let the tires down and throw some **** outta the trunk, then pull into the lanes and bust off a 6 sec pass. Google Lenco transmission its a manually shifted gearbox, not in any way an auto lol
#68
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#69
Sorry kids not trying to have a pissing contest, as previously stated I didnt start an auto vs manual benchracing thread.
I started a thread asking what the fastest v1 pass is and so far looks like it is indeed an 11.60 do we all agree?
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#72
lmao are you serious? a manual valvebody AUTOMATIC is just that, an automatic with a torque converter. A Lenco is a MANUAL transmission in which gear changes are made by manually moving a lever(s) into the next gear, and this said manual uses a clutch. because it is a manual. for the sake of the last two arguments brought up, A lenco and a t56 are similar in that they are both MANUAL TRANSMISSIONS lol, Just like how a manual v body th400 and a 4l60e are both AUTOMATIC TRANSMISSIONS
itsslow98, if a lenco is the same as a manual valvebody th400 then that means essentially a manual valvebody 4l60 is the same as a t56 right? lmao
With a Lenco,you don't need the clutch to change gears. There are planetary gears inside like an automatic trans. When you toss the levers,you are changing gears just like an automatic trans does on it's own. This allows for very quick gear changes because you never disengage the engine from the trans.
You basically use the clutch one time to move the car, after that you shift without it.LMAO
Fast forward to 2:20
#76
My plan is the 8.8 from CS, 285 DR's and a quick learning curve as I have never ran at the strip before. Problem is I am also going to have to do a rollcage... To do it right for the four door is not going to be cheap. But I think 10's are definitely possible.
#77
You obviously dont know what a Lenco is.....from there site..
http://www.youtube.com/watch?v=2zx54zjDU4s
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#79
Agreed. I'm just hoping to crack into the 11's. I just got a set of heads, now trying to decide on one of three almost identical cams to go with.
#80
