Maggie guys with slip issues: check this
If ur having slip issues or stretching belts like me then here's the
Fix. I was having slip issues with my IW balancer and 2.6 upper but
This belt solved it all. No more stretch or slip.. Verified by my boost
Gauge. I've got about 5k on it and took it off to take a measurement
Same as the day I put it on! My gatorback had stretched over 3 inches
So those are alot of nice specs to tout as improvements. What are the downsides to this belt? There has to be some compromise somewhere (other than high cost). Is it noisier that stock? Does it fail the same way?Will it wear out pulley bearings faster? Any insight?
I'll probably buy one for my next belt whenever that happens if there are no real negative attributes to having it. Nice find.
Interesting. Too bad I just replaced mine a couple months ago with the "regular" gates belt. No stretch on it so far though.
Got a link?
Do you have any pics of the V2 acc idler pulley?
