04-05 vs 06-07 magnaflow exhaust?
B&B is a few hundred more and I won't see much gain between 2.5 and 3" unless I went forced induction. I doubt that will ever happen with this car. Price per HP is too pricey compared to other cars I own. I just want to get close/above 400whp.
I'm still deciding on what exhaust or if I should even buy an exhaust as there is conflicting information. I was looking at the magna exhaust also and I think I could do 600 but around 1k, doesn't seem worth it.
If the stock exhaust is so good why does anyone buy exhaust?
Sound, and each vender claims 15hp and 15-20ft lb torque. I'm sure there is a slight power gain with less restrictive mufflers and better X-pipe.
That or dumps behind the headers.
http://performancepeddler.com/catalog/
I also have some UMI Motormounts on the way from ColoradoSpeed and I'll have HPTuners in a month.
Buy the unpolished magnaflow muffers (same thing in the full cat-back) from Jegs for $80 each. Cut old mufflers out, weld in new ones with a couple of 45deg elbows from the auto store. Take the money you saved, and buy LT pacesetters for $450 and ditch the cats. Everything bolts right up (mostly) and itll get you a lot of bang for your buck. Leave the stock resonator/X. Drones a tad in 6th as others have said, but not bad at all.
