The cure for drone-- 1/4 resonance pipes aka J-pipes aka Helmholtz tubes
Gents, the mufflers and anti-resonance pipes are coming off my car this weekend, and are for sale. I'm taking a new job where I have to pull into a LEED Plantium building every day and park alongside Volts, Piruses and Teslas, and just can't be rocking this kind of volume. I'm going back to the stock muffs for a more stealth setup.
These are and will remain excellent straight-thru muffs that do not resonate. The anti-resonance pipes are adjustable to fine-tune to your setup. Selling for $200 for everything, plus shipping. Will make a new post in the classifieds. Thanks.
I wonder if there's some benefit to making the tubes two different lengths and perhaps covering a wider range of rpm. I know stock Foxbody 5.0's had two different length mufflers to kill drone. I'd think two different length tubes would be similar.
For those that want a bit of background info and to do their own math. I posted this.
https://ls1tech.com/forums/conversio...ps-solved.html
I'm gonna try lining my trunk/floor with sound deadener before I look into J-pipes.
www.sounddeadenershowdown.com has some good info on how to get rid of interior noise. I'm starting off with CLD tiles.
Old School Heavy
Some interesting information for people interested in this topic. Where I live there are several draw bridges. The draw up section of the bridges has steel grates to drive on. Take any car that drones, and drive it over these steel grates and the drone instantly and completely disappears. This tells me that most of the drone that one is experiencing is being reflected off of the pavement back at the floor boards of the car and/or is resonating in the area between the car and the road.
Food for thought.
Food for thought.
#32
Food for thought.
Food for thought.
#33
Passing over a grate allows that awful resonance to dissipate away from the car. There is no way to replicate this with your exhaust setup, except maybe to dampen the entire bottom of your car, but that adds a huge amount of weight and is never completely successful.
#35
Bringing this back up with a question. If one is running dual 3" exhaust pipes what diameter J-pipe would one need to run? Would a 2.5" diameter work or would you need a 3" diameter J-pipe?
#36
I didn't read the whole post.....on one of my cars I had a Magnaflow and it droned. I called an complained and the response was this is a high performance exhaust.....unacceptable after spending $1000.00 (that's ne of the reasons I will never buy anything from them again). The gentleman on the phone told me to replace the resonator with a longer one. I did and it cured 90% of the drone. I ended up spending an extra few hundred bucks replacing the resonator, cutting down the exhaust to fit like a factory one and getting welded together instead of clamped. I am **** that way. They use quality stuff, the parts look good and my wife would always get compliments on the sound, but I didn't like the drone or the fact the exhaust tips stuck out just enough to read their logo. That's the other reason I won't buy anything from them again. I also learned my lesson......never replace stuff on your wife's car with aftermarket parts.
I was watching Overhauling one night and they were doing a 2014 Impala. Magnaflow built a custom exhaust for it and when they showed the exhaust the guy built it with two short resonators (it looked like he went from the cat to the Y-pipe). I'm wondering if that cured the drone.
If you look at aftermarket mufflers for Porsches and BMW's the most expensive ones have those J-pipes welded to the mufflers already.
#37
It's been proven to work many times in the past on many different vehicles: G8GT, Mustangs, CTS-v, GM trucks and cars with AFM, etc., etc.
Here's some references:
http://www.g8board.com/forums/showthread.php?t=16077
http://forum.grrrr8.net/showthread.php?t=10801
http://www.performancecarweb.com/showthread.php?t=144
http://forums.corral.net/forums/gene...tely-gone.html (Long, but the best thread of all)
http://www.silveradosierra.com/exhau...it-t12607.html
http://www.pro-touring.com/threads/9...J-bend-exhaust
http://www.camaro5.com/forums/showthread.php?t=102075
http://www.cadillacforums.com/forums...ltz-pipes.html
https://ls1tech.com/forums/cadillac-...ltz-tubes.html
Make a "sticky" of this if you like.
Nobody deserves to drive "droned".
#38
Honesty if I had to run a j pipe because of poor r& d from a exhaust manufacture I would be pissed. I think it looks crappy and half assed.
I understand the option is good for a budget muffler delete route,but if u are in the market for a cat back why not just buy one that doesn't drone ?
I am a corsa fan, I have kooks running into race cats with no resonator , and corsa mufflers. Zero drone. Can't get any better than that.
I am though surprised after all these years no one has made a corsa muffler clone.
#39
Originally Posted by cammedv
I don't understand how magnaflow advertises their exhaust as "drone free"
I have gone through three corsa systems on three different vehicles and each had annoyin drone while cruisin...
Lesson learnt so no more corsa for me...
#40
Why do you guys stick with magnaflow mufflers if they have this drone that i keep hearing about?
I understand that this j pipe fixes it but just wondering why you would go through the hassle for that particular muffler when there is better flowing ones out there without the drone?
Ive been super happy with my hooker maxflow mufflers
