Maggie rear pulley swap a NO go
The 2.9 rear pulley they put on the jack shaft just won't fit the bearing hub. I ordered a 3.2 to make it work. It'll be over driven but not as easy as I thought. Just an FYI . Ill update what I get out of it once the pulley comes in in a week :-(
ill do the formula after i get it back together and see what front pulley ill end up with. at 10lbs my iat's werent too bad. im hoping to get another couple pounds of it and solve my slip issues i had with the 2.6. prolly gonna end up with a slight over driven rear,over driven balancer and 3.0-2.8 front depending on iat's and the curve i get. going from the 2.8 to the 2.6 gave me 25 ft lb's of torq so we'll see
This is it for the Maggie though.. Little spray to get me thru the summer then ill decide from there
