Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Proper rotor change technique
Old 05-06-2013, 12:15 PM
LAYGO's Avatar
Default Proper rotor change technique
I learned that the 4 torx head bolts on the backside of the calipers aren't there to remove them, but only learned that after destroying about 3 of them. Dealership doesn't sell the bolts separately.
Instead, I had to take it to my mechanic & they were laughing at me because there are 2 18mm bolts mounting the caliper & voila. I swear I searched here for how to get it done, but no one mentioned how to remove the calipers.
(BTW, this was my buddy doing it because he said he could knock out brakes no problem. I was simply replacing my warrantied rotors/pads from Brakemotive)
Old 05-06-2013, 12:18 PM
IdriveaV's Avatar
I dont think your suppose to split the calipers at all, not good for them, just unmount the caliper and pop the new rotor on
Old 05-06-2013, 12:26 PM
LAYGO's Avatar
I split my driver side front before I realized about the 2 18mm bolts.
Old 05-06-2013, 01:28 PM
DougNuts's Avatar
Buy a service manual of some sort.
Old 05-06-2013, 01:32 PM
ramairetransam's Avatar
holy hell , what a fail .
Old 05-06-2013, 01:38 PM
camaroz98's Avatar
lmao sorry man live and learn tho, i had a co worker try to change is rotors on a GTI sat watched him remove both axels for no reason and had a good laugh
Old 05-06-2013, 01:44 PM
rjoffe's Avatar
Doh!!!
Old 05-06-2013, 01:50 PM
IdriveaV's Avatar
Thats not good, there should be a little seal in between the two halves, you didnt mess that up did you?
Old 05-06-2013, 02:18 PM
slowlaneblues06's Avatar
Were there any Frosty Beverages involved in this?
Old 05-06-2013, 02:36 PM
HR2L's Avatar
Only way to do it!
Old 05-06-2013, 02:39 PM
Stone17's Avatar
I just got my brakes from Brakemotive.
What was wrong with your set?
Old 05-06-2013, 02:56 PM
HR2L's Avatar
Nothing was my impression when I read the OP.
The process of performing the task of replacing his Rotors is where the problem arose.
Old 05-06-2013, 03:10 PM
NIKDSC5's Avatar
Old 05-06-2013, 03:15 PM
LAYGO's Avatar
Not true, I had my BM rotors/pads initially installed by my mechanic about a year ago. They've warped twice on me. BM will say "disk thickness variation", but I saw the rotor being turned on the lathe.
I watched my buddy do the brakes on a couple of other vehicles before letting him tackle this, so I figured he could do it.
I don't know about the seal between the halves. There wasn't much there. I believe the previous owner had gnarled up the male torx bolts & we made them worse. Dealer wants a whole new caliper & doesn't sell the bolts separately . . . at $280 pop. O'Reilly wants $150 + $90 core/caliper.
Old 05-06-2013, 08:20 PM
Stone17's Avatar
Cheaper on Amazon.
ACDelco 172-2288 Caliper Assembly : Amazon.com : Automotive ACDelco 172-2288 Caliper Assembly : Amazon.com : Automotive
Old 05-07-2013, 05:48 AM
kciaccio's Avatar
Better yet..
ACDelco 172-2308 Caliper Assembly : Amazon.com : Automotive ACDelco 172-2308 Caliper Assembly : Amazon.com : Automotive
Old 05-07-2013, 10:23 AM
LAYGO's Avatar
Originally Posted by kciaccio
I'm tempted to get all 4. Besides the gnarled up stuff, these things have some dust that's caked & baked.
Old 05-07-2013, 10:39 AM
LAYGO's Avatar
This is after spending 15 mins taking a brake kleener soaked terry cloth to the caliper & *STILL* there's black/crusty crap everywhere.
Gnarled up torx head:
Old 05-07-2013, 03:53 PM
Chrismikeb's Avatar
That's why I get a rag and clean them every time I wash the car! U don't really need to buy new ones all around, just get them blasted and powdercoated. Then u can have any color u want!
Old 05-07-2013, 04:29 PM
kciaccio's Avatar
If I could get them for $80 a piece brand new I would just replace them. Be careful when you bleed them. If you don't get all the brake fluid residue off afterword the paint peels off the caliper. FYI.
Quick Reply: Proper rotor change technique
