Time to step up the Brake Game
http://www.gmhightechperformance.com...s/viewall.html
Here is an article where they ran the V2 caliper on a smaller rotor (355mm) with no noted issues. so we will see.
Isn't that a 4th gen Camaro aka f-body.. Looking at the pictures the overlap doesn't appear to be that bad. If the distance between the mounting holes and top of the brake pads is similar between calipers and the caliper doesn't run into the raised hub area than the overlap should be min. This might be the case between 4th gen Camaro and v2, but could be something entirely different between v1 and v2. Can you measure this distance between your new V2 caliper and old V1 caliper?
http://www.gmhightechperformance.com.../photo_16.html
Why is there such an argument on over lap?
Without the larger rotor the upgrade is damn near useless. Get some stock V2 rotors and drill them out for the V1 six lug, to atleast hold you over until you can afford better rotors. If you're spending 700$ on the calipers you can spend another couple hundred (if that) on some oem (or even used) front rotos as well.
I'm interested in this as well. The V2 pads will have more contact area on the V1 rotors even with the 1/4" overlap. Ideal? No...making a two ton car the stops pretty damn well a little better (while looking damn good) for a few hundred $$$ is a win in my book.
price isn't necessarily cost prohibitive.. gives the car an updated look too..
can you transfer the current front calipers to the rear?.. perhaps it might narrow the newly increased gap btw f/r. I have no idea what the specific bias numbers are, was just a thought.
The excess pad not contacting the rotor was tested by AAIIC and found to be about .25in. This makes sense as the increase in the radius from v1 to v2 rotor is roughly .25in
My end goal is to buy the two piece V2 sized rotors from racing brake. However as they are $1200 i am going to run the v1 rotors in the near term.
By the way OEM rotors are roughly $225/side
Based on information from the Cadillac forums thread AAIIC determined the changed in F/R bias to be about 2%
#34
Chamfering the pad edge would be recommended if you are going to use it for any length of time in that setup. It would alleviate the noise issues that will be created.
Without an ABS pressure model re-tune I don't see very much gains from doing this upgrade.
Unless the effective surface area of the 6 pistons is the same as the "old" effective surface area of the 4 piston caliper and fluid volume/displacement remains the same there will be issues with pedal travel and pedal force. Not to mention Booster sizing may be inappropriate or too aggressive from a V1 with V2 caliper, read overly sensitive brake pedal, or time to lock too aggressive.
With all that being said.. It'll "work", as noted by others that have already done the swap, but it won't be optimized. I would compare it to putting in a bigger cam in an engine without tuning it.
The worst thing that could probably happen is that because the ABS module isn't setup properly for the differences it could potentially put less work in to the front calipers and send more to the rear, wearing them out quicker and bringing up the potential for rear brake hop on severe decels.
I'm all for upgrades, but this one might not be the best bang for the buck.
#35
I think we got lucky, Barrok. Reviews from people that have done the mod have been universally positive. But I think OnefastV might be the first one to run V1 rotors for an extended time.
#36
ive actually done this a bunch of time on stunt bikes..we make a bracket that allows us to use a front 4 piston caliper on the rear rotor for a hand brake. pretty much the same idea.. the rotor is slightly smaller than the pads surface so after a 100 miles or so i used to just pull the pads and take a dremel to the area on top that was clearly marked out by the rotor. use a flat head screw driver and a hammer and knock the useless pad material off. worked like a dream. shouldnt be much different
#38
So in response to Barrok69 I wonder if the V2 abs pump, master cylinder, and booster are simliar (or possibly the same)?
Because like Fuzzy said, people have done this mod to their cars with nothing but great reponse and a bunch more braking force. So....yeah......?
Also, when you are talking about fluid volume/movement (I'm no expert) but unless the V2 brake lines are a different diameter the only thing really affected would be brake pedal travel, no? as the lines will restrict the flow, but the calipers will (possibly) require more fluid? So then I could see how fluid flow could affect brake timing.
So, there is the fact of the diameter of the caliper pistons. The V1 I believe are quite a bit larger than the V2? So 6 little piston (fluid volume) to 4 large piston (fluid volume) may be very similar. I guess what I'm thinking is the 6 pistons help with is more "rotor wrap" or more pad surface area along with a larger rotor clamped upon in more locations = better?
This is me just open thinking. I have no previous experience or knowledge on how braking systems are designed to function "ideally" But I do know they are designed that way.
#39
I'm still interested in the 60ft braking numbers with this setup. We're already at 112 feet, which is rare territory for a sedan. 93-100 would be among top 25 in the world for any car
