Powertorque slave ?
So I just purchased an ls7 clutch setup from a member on here and I also have a powertorque ls7 slave. I just want to make sure before I rip everything apart that I don't need a shim or anything else for the slave. It should work fine without anything right? My concern came when I was about to buy a full kit from a supplier on here and he said I need his modified ls7 slave or it will not work. He also said he never heard of anyone using this slave even though I told him several people have on the board. I picked up my slave for $90 and his modified one is around $220. Will I be safe with the power torque and no shim? Or should I sell it and go with the modified one? I just don't want any problems and have to pull the trans back out. Also what torque do I tighten the flywheel and pressure plate? 48ft/lbs on each? Thanks.
I never have understood why people cut the trans up to install an LS7 slave. That line bends pretty easily. As long as you don't kink it your good. You only have to move it an inch lol
