Rear Wheel Lug Bolts
Well, it was inevitable: I snapped one of the lug bolts off one of my rear wheels. I've already got replacement bolts, but the question is, what tools and steps do I need to take to remove the old ones?
Last year, I replaced all of the lugs on my front wheels, but the rear wheels pose a greater challenge, since those disc brakes are in the way. You can't just pound out the old bolts once the wheel is off. I suspect I need a huge socket and a breaker bar, but I'm not 100% sure.
Thanks!
Thanks!
When I get home tonight, I'll get you a part number. They're just Raybestos lug bolts. Better than OEM, but not as good as ARP. I'm probably going to replace the front lug bolts with slightly longer ones, since I recently installed a set of front wheel spacers fabricated by MightyMouse that eliminate that slight underbite the CTS-V has. The part number I'll give you is more than sufficient for all of the wheels and lugs we can use.
A touch under 29,000. If you're worried about your bolts, don't. I have a nasty habit of over-torquing stuff. I have to use a torque wrench for critical stuff that's torque sensitive and so that I don't accidentally break something I can't easily replace.
To date, I've broken 7 of the stock lugs and 11 pieces of 3/8" drive hardware (sockets, wrenches, and extensions). 15 if you count that Popular Mechanics rounded bolt extractor kit. Those things lasted all of three seconds apiece.
Never broken a Raybestos lug bolt.
Lug bolts/studs, you mean. But yeah, they definitely don't have sufficient tensile strength to handle being torqued 100+ times per year. I also had to upgrade to solid lug nuts after I torqued the covers right off the stock nuts. Since upgrading to Forgestar F14 wheels, I've been running 24 matching gloss black spline drives, which were worth every cent. The finish on the cheaper black lug nuts wears off pretty quick.
That and its something you learn once you see someone snap one at a track event.
I was just curious to get an understand of your vehicle.
I'm not sure what knowing my mileage tells you about the CTS-V. It's all about how the vehicle is maintained.
A car with 500 miles on the clock and no oil in the engine is going to be in much worse condition than a car with 50,000 miles and a fastidious owner. As a stickler for cleanliness, I go right for the engine bay to get a feel for how someone maintains their car.
I was simply pointing out that your basis for asking the question didn't adequately support the question.
And for what it's worth, I wish people would call me out more often. Praise doesn't do anybody tangible good.
You arent that hyper-analytically....not even close to it.
Hyper-analytically is well found in many people in my industry. and my basis for asking, i never disclosed. general understanding is not the basis for anything tangible.
After searching for about 20 minutes, the best I could find in ARP was the 100-7709 (sold in boxes of four, but otherwise identical to the 100-7710, sold in boxes of five). They cost about $4 apiece and have a 1.850" (47mm) underhead length, which may be too long unless you a) have big lug nuts or b) need that extra 7mm to compensate for a thin wheel spacer.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Just out of curiosity, how many of the wheel studs you've broken were with the cheaper lug nuts you were running at one point, and how many were with the Spline Drives? Years ago, I broke I think 3 or 4 stock wheel studs over the course of 18-24 months on my Subaru while running generic chrome lug nuts. Since switching to quality lug nuts (Spline Drives and RAYS duraluminum) about 9 years ago, I haven't broken a single wheel stud, despite countless wheel changes for brake work, auto-x events, track events, winter/summer swaps, etc. I didn't change anything about my technique for installing the lug nuts (always done by hand with a ratchet and torqued to spec), and the hubs still have stock wheel studs, so the only variable that changed was the quality of the lug nuts.
