remote clutch bleeder fail - pics!
I ordered a clutch bleeder from Tick Performance. It doesn't fit the stock LS6 slave.
Here's a pic of the stock slave attached to the transmission.
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04155842_zps5e03a75d.jpg)
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04155802_zpsb3839d05.jpg)
Installing the Tick Performance speed bleeder:
Up
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04160706_zpsfbf3cc83.jpg)
Down
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04160622_zpse4d21310.jpg)
Side
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04160826_zpsaa4cd919.jpg)
Here's the only side that works:
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04160938_zpse48118e6.jpg)
Bending it back to clear the bellhousing contact surface...not good.
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-02195537_zpscb0a16de.jpg)
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04161000_zps0ce0591b.jpg)
The stock bleeder tightens very nicely. The Tick Performance was a kinda loose. Here's a few shots of the end fittings.
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-04160343_zps3e5c3344.jpg)
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-02195718_zps4148b41a.jpg)
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-02195743_zps0e6224d8.jpg)
I purchased part# TPSBLC6
http://www.tickperformance.com/tick-...6-04-07-cts-v/
Just giving a head's up of what you get. So instead of fumbling around with end fittings that don't work (btw the two ends are different thread sizes and are not interchangeable) I decided to purchase the Mityvac and give it a try.
chime in if you know of something I overlooked. Again, the 45 degree end fitting and the straight are different thread sizes so no reversing them.
Thanks!
Up
Down
Side
Thanks!
Did you email them and ask about what you'd need for your application? I've never bought anything from them, but in anticipation of swapping to an LS7 clutch (and slave), I emailed them a long time ago to inquire about what parts I would need to fit my application. They were very helpful and linked me directly to the part I'd need (which happened to be the 2010 Camaro part)...
I posted so others don't fall into blind faith. You are correct, call every vendor when installing anything other than OEM.
I appreciate any and all feedback. I dislike the work-around that is involved with something that should be simple and effective.
The spacer is for people that use the stock slave with a single clutch, or for the ones that got rid of the dual mass flywheel and kept the stock disk and pressure plate. In your case, you don't need it.
I would just bend the bleeder if I were you, unless you want to wait a few days for a different one.
Thanks!
Hate to tell you that the Mityvac like the one in that link did not work for me.
I screwed with it for 20 minutes or so and it did not work. I had it at 20-25 psi IIRC.
Maybe it just takes a really long time, don't know.
I have this one:
When I got tired of ******* with it, I took out this bad boy:
It takes longer to get this set up than for it to get the job done. 1 minute tops, and it's done.
Takes me about 5 minutes to set this up. ******* love it!
I have this one:
I have this one: Amazon.com: Mityvac MITMV8500 Silverline Elite Automotive Vacuum Pump Kit: Automotive
Mityvac MV6835 Vacuum Brake Bleeding Kit : Amazon.com : Automotive
I used the same bleeder with a complete LS7 setup and had no issues.
Use the PowerMotive setup. Works in 2 minutes.
I screwed the fitting all the way in to the slave without the hose attached and it's pretty loose when it bottoms out - I can wiggle it dry fitting it. That's why I took a close up pic of the two different fittings - stock vs. Tick Perf.
I've been using this on all my cars. I plan to use it for the clutch also.
http://www.harborfreight.com/brake-f...der-92924.html
Hate to hear that you're having bad time with their application guide, they really helped me out when I placed my order. They even called me to ask what I was actually using it in with what clutch. Great service.
Bending the fitting or cutting a notch in the bellhousing is unacceptable. I called and I was told to send it back and to get the 2010 Camaro speedbleeder - wtf??? So I guess the scenario is...purchase 2004-2007 cts-v specific speedbleeder, find out it fits like real s**t and then send it back in to get the model car that I don't have.
To be fair Tick Performance mentioned that they suspect not all cts-v bellhousings are the same. I took a pic of a Mallet cts-v, not sure if it has a T56 or not but the bellhousing was definitely different.
EDIT: THIS IS A MALLETT CTS-V - NOT MINE (JUST A REFERENCE PIC SHOWING DIFFERENCES)
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-07-05141711_zps84272086.jpg)
I spoke with Martin about this about a year ago. The one that fits our application is the Camaro bleeder. This has been discussed in other threads on CF. It has been mentioned to Tick to change the website to reflect this...but, well, you know.
The big circular hole in the bottom of your bellhousing, is that something you've done or factory? As many times as I've been under my car, I'm 99.9% sure that's not on my bellhousing.
