Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Ah FAWK! Header bolt broke
Old 09-08-2013, 06:18 PM
Blown_Red_97z's Avatar
Default Ah FAWK! Header bolt broke
Taking off the bolts, I get to the last one on the passenger rear. I see it sticking out and thought it was odd since i didnt loosen it, then it just dropped out. So it broke off without being turned
Ideas on getting the rest out? They are on pretty loose i was thinking about trying some jb weld or something. I dont have a welder here.
Old 09-08-2013, 06:45 PM
brack86svo's Avatar
Is the broken part flush with head, or sticking out? JB Weld is not going to work. Welding a nut on to it is two fold - gives you a nut to turn, and heats the bolt to help remove it. JB won't bond well enough to turn it out.
liqidvenom's Avatar
if it is broken near the exit, you could dremel a straight cut into the head and use a screw driver to back it out
Old 09-08-2013, 07:50 PM
It's kind of near the face of the head. The problem is trying to get to it since its all the way in the rear. Has anyone had luck using those extractors you use with a drill? Not sure I can even get it in there though...
Old 09-08-2013, 07:56 PM
heavymetals's Avatar
That is a very tight fit and you need a rt. angle drill.
MOD HELL.
Do it right, remove the head.
Now you know why beer was invented.
Old 09-08-2013, 07:59 PM
Redchevyman's Avatar
If you can drill a 1/8" hole in the bolt you can hammer a torq bit into it and back it out. I had two broken bolts on the 5.3 I bought from the junk yard. Hopefully you will have room to drill.
Old 09-08-2013, 08:02 PM
Harbor freight has cheap right angle drills if you need one.
Old 09-08-2013, 08:11 PM
Item 92956 is 29.99 or you can use right angle attachment on your drill for $15 Item #69337
Old 09-08-2013, 08:20 PM
I searched a bit more. Everyone says use a welder. Maybe I can see if I can get a mobile welder to do it. There's really no room to work though.
Old 09-08-2013, 09:21 PM
Good luck.
They will have to be a contortionist too.
That last rear bolt is a SOB.
Old 09-08-2013, 09:39 PM
54inches's Avatar
I had the same issue last week.
Used a right angle drill to drill a 1/8" hole so I could use an easy out. broke the easy out.
It's my DD, so I put it back together and made sure to torque the headers down evenly and in a good sequence.
Fortunately, no leak, but the head will have to be pulled eventually.
Old 09-09-2013, 12:05 AM
philistine's Avatar
This happened to me on the driver side though. Drilled, broke an EZ out etc. At the time it was my DD so I just bolted it back up - no leak.
If it's stubborn, then you gotta pull the heads. You booger it up too much...new heads or machine shop.
Old 09-09-2013, 12:27 AM
Luckily I have another dd. I work with a lot of good welders so I'm going to see if they can help me out. Pretty bummed though was trying to get the car prepped for the meet in so cal next weekend. With my schedule I won't be able to get it done in time unless I just keep going and worry about it later. I swear this car doesn't like to be modified, the revshift tranny mount was a pain to get in, the shifter rivets didn't want to com out, now the bolt breaks.... Ahhh the joys of moding!
Old 09-09-2013, 12:38 AM
I used the short torx bits because the easy outs break too easy. If you break a torx bit you can still weld afterwards.
Old 09-09-2013, 12:44 AM
Valid point. I'll hit up harbor freight tomorrow. If everything fails ill pull the head, but then it's l76/l92 time with a cam. I didn't want to jump to that just yet though.
Old 09-09-2013, 03:12 PM
jsnm's Avatar
Yep been here too,ended up just pulling the heads and having Advanced Induction do the machine work.
Good luck with it though,hopefully you'll get lucky and can get it out without having to pull the head.
Old 09-09-2013, 07:52 PM
4doortypels's Avatar
Local machine shop charged me 35 to remove one... pull the head and do it right the first time. It will be worth the time
Old 10-04-2013, 11:46 PM
Well to update: had to take a few weeks off (school, wife's bday, life, etc.) and got back in it tonight. Tried the Dremel cutoff wheel to cut a slot and use a flat tip to back it out. That didn't work. Bought a short right drill and left thread bit. I'm digging into the bolt, going to retap to 10-32 and try to dig the bolt out. If it doesn't work I'm putting it back together and seeng if it leaks. If it does leak, I'm pulling the heads and doing head, intake and a cam....I'll see tomorrow what happens
Old 10-04-2013, 11:55 PM
Fuzzy_Wuzzy's Avatar
So what i am hearing here is that you need to screw up the gasket before you re-install it...
Old 10-05-2013, 12:05 AM
An exhaust gasket? Yes who cares it's like $12 on amazon. A few people on the forum are running with broken off bolts, no leaks. That's why I say if it leaks I'll pull the head but I'll try everything before that. The reason being is if I pull the passenger side head, I'm not going to want to put the stock 80k mile springs, pushrods, rr's, gasket, etc back on... And if I upgrade the passenger side head, why not do the driver side head? And if you are going to pull both heads why not upgrade at the same time? And if you've already pulled the manifold, port the stock or upgrade as well right? And if you've dug that deep, **** put a cam in at the same time... Just saying it makes sense to me. Plus it's not my dd so it can be down for a while
Quick Reply: Ah FAWK! Header bolt broke
