bmr anti wheelhop kit with revshift cradle bushings?
Finding out my car has the BMR opinion brace and anti wheelhop kit has me thinking..... could I replace the cradle bushings with revshift ones, and still use the kit?
Also....I have the revshift diff bushing sitting here, can I also run this in conjunction with the BMR pinion brace?
I'm in the same boat, didn't do anything to the cradle...just decided to figure it out some other time. Had all BMR stuff from the previous owner and didn't realize it until i got under to switch out the cradle bushings.
You could keep the BMR cross brace and run that with the Revshift cradle bushings. Otherwise get rid of the BMR anti-wheelhop kit. It is useless.
As far as diff bushing with pinion brace. I currently run that setup without any issue. If anything it adds a bit of structure to the weakest part of the diff.
